On startup I get message:- c:\program
On startup I get message:-" c:\program files\java\jre6\bin\jusched.exe can't find this file." All else seems ok. How can I stop the msg appearing? I'm on XP. This began after recent Java update. Regards Dave
  • 2,517 Answers
Uninstall the java. Restart the computer. You can't see the message again. But java is important for computer that's why install it again from net.
Thanks.
Posted on Feb 04, 2010
In minecarft what does this mean: hs_err_pid#
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Jan 22, 2013 | Microsoft Corporation Xbox 360 Live...
Unable to access jarfile c:\Program Files\Java\jre6\lib\librtexec.jar
sounds like this would be a java-script error. you can try re-install java-script http://www.java.com/en/download/ it might be a good idea before you re-install, to uninstall any instance of java from the control panel - add/remove programs, or programs and features section for vista/windows 7
Jul 07, 2011 | Computers & Internet
Java WAR file is stored in which location?
It's either in the directory where you unpacked the application you just installed, or under the \java\jre6\lib directory (on Windows), assuming you're running Java 1.6 (or java 6.x). If it's not under the latter, then you should try using Windows Explorer (or that File Folder icon) and open the directory where the application resides. Then just start that program. If that works, then you'll need to modify whatever shortcut or script to include the "-classpath=X" right after the "java" command, where "X" is the full path to the WAR file.
Feb 19, 2011 | Computers & Internet
For windows xp not found c:\Program Files \Java
Java was corrupted. Update to the last version from here
http://www.java.com/en/download/manual.jsp
Jun 30, 2010 | Gateway GM5048 (6304) PC Desktop
Java installation problem
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
Error: 25099 during Java installation This article applies to:
  • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
  • Browser(s): All Browsers
  • Java version(s): 6.0 , 6u10+
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Nov 08, 2009 | Computers & Internet
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
  1. Go to Java.com
Sep 17, 2009 | Microsoft Windows XP Professional With...
Java stopped working
What version of Java do you have running? Have you tried uninstalling the JVM (add/remove software in control panel) and re-loading from the most current version from Sun? V6.16 is most current:
http://www.java.com/en/download/index.jsp
Sep 02, 2009 | Acer Aspire 5735 Notebook
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
M3plugin.dll missing module at startup
Your web browser has been hijacked by "adware" called "My Web Search"... The fix is involved, but not impossible.
First, uninstall the My Web Search program using standard Add/Remove Programs. Also uninstall any of the following items associated with FunWebProducts.
  • My Web Search (Smiley Central or FWP product as applicable)
  • My Way Speedbar (Smiley Central or other FWP as applicable)
  • My Way Speedbar (AOL and Yahoo Messengers) (beta users only)
  • My Way Speedbar (Outlook, Outlook Express, and IncrediMail)
  • Search Assistant - My Way
Download a free copy of a program called HijackThis.
Reboot your Computer and run the HijackThis program.
Scan for and fix any of the entries shown below.
  • R3 - URLSearchHook: (no name) - {00A6FAF6-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
  • O2 - BHO: MyWebSearch Search Assistant BHO - {00A6FAF1-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
  • O2 - BHO: mwsBar BHO - {07B18EA1-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
  • O3 - Toolbar: My &Web Search - {07B18EA9-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
  • O4 - HKLM\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
  • O4 - HKCU\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
  • O4 - Startup: MyWebSearch Email Plugin.lnk = C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
  • O4 - Global Startup: MyWebSearch Email Plugin.lnk = C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
  • O8 - Extra context menu item: &Search - http://bar.mywebsearch.com/menusearch.html?p=ZWYYYYYYYYUS
  • O16 - DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - http://ak.imgfarm.com/images/nocache/funwebproducts/ei/MyWebSearchInitialSetup1.0.0.8-2.cab
Next, open My Computer, Drive C, and double-click on the Program Files folder
Right-click and delete the folders for:
  • FunWebProducts
  • MyWebSearch
MyWebSearch should now be completely uninstalled from your computer.
There will be some minor registry entries left behind by the uninstall, however these can be cleaned up by running SpyBot Search and Destroy. SpyBot is also available online as a free download.
Good luck!!
Sep 11, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
