Question about Aeris A1 Octo
How do I make the connections with the main valve, I am buying a new octopus not yet assembled,
    Scholar:
  • 190 Answers
If I understand your question properly, all you need to do is remove one low pressure plug from the first stage regulator, then screw the hose end in from the new octopus.
Posted on Feb 04, 2010
Octopus box what do I need to use it
If I'm reading this right you have an octopus which is a second emergency regulator for your buddy if he is in trouble. Where the original regulator hooks to the valve that goes on your tank ther should be a blank with a screw in it . This is where the octopus screws in . You will have a rubber o ring in side. Put it on the end of the threads from the octopus hose and insert it into the hole the screw once occupied.. The screw is just there to fill the blanks hole and can be thrown out.
Apr 13, 2018 | Scuba Diving & Snorkeling
Where in New Zealand can i buy a holden vectra octopus hose
2001 Holden Vectra Reviews - Carsurvey.org
www.carsurvey.org > Holden > Vectra
  1. Cached
  2. Similar
Aug 4, 2016 - 2001 Holden Vectra GL 2.2 from Australia and New Zealand ... 'Octopus' coolant hose blew. This is stupidly designed by some idiotic engineer ...
PartsWorld : Holden Vectra Parts - Right Parts, Right Service, Right Price
https://partsworld.co.nz/parts/holden/vectra
  1. Cached
  2. Similar
Not logged in ( login ' register ). PartsWorld is New Zealand's Largest Auto Parts Recycling Chain ... Holden Vectra Parts - Select a Series. help. Don't know your ... Missing: octopus
Search Results for radiator hose js vectra - Telstra Media Search
search.media.telstra.com.au/?location=&searchIndex=australia...hose...vectra
  1. Cached
  2. Similar
Products 1 - 20 of 103 - TBAP Radiator HOLDEN Vectra JR/JS 2.5L/2.6L 6Cyl Auto . ... /catalogues/hose-application-catalogue-aus-nz-october-2012.pdf.
Holden Vectra Heater Hoses ' Sparesbox
https://www.sparesbox.com.au/vehicles/holden/vectra/heater-hoses-category
  1. Cached
Shop Holden Vectra Heater Hoses online at Sparesbox Australia. FREE Shipping on orders over $50. Missing: zealand ‎octopus
Too expensive to repair - what next? - Servicing - Automotive ...
forums.whirlpool.net.au > Automotive > Servicing
  1. Cached
  2. Similar
Jan 5, 2011 - Rather than scrapping, get the bottom hose fixed (Should be like ... If you do end up buying a new car, always buy japanese or commodore/falcon. ..... Holden vectra, If it is V6 vectra i can tell you right now it wont be the head gasket. .... broadband · Regional · Last century; International: New Zealand ISPs.
Holden ' Car parts & accessories ' Trade Me
www.trademe.co.nz > Trade Me Motors > Car parts & accessories > Holden
  1. Cached
  2. Similar
Holden for sale in New Zealand. Buy and sell ... Holden Commodore VL, Manual steering Rack & Inter shaft .... Holden VT-VZ Front Electric Window Regulator.
New Zealand can buy holden vectra octopus hose Google Search
Nov 11, 2016 | Holden Cars & Trucks
My octopus leaks from the head (not the hose). Could it be an internal problem?
A rebuild or simple adjustment can make it stop leaking if it is coming out of mouth piece if it is leaking from anywhere but mouthpiece or hose connection it needs service.
Mar 26, 2012 | Oceanic Swivel Octopus, Scuba Diving...
GE Model WCVH6800J Error Code 04. I do not have list of codes for this model, so I need translation.
TROUBLESHOOTING CHART
Codes Description Action
22,23 Fill problems
• Ensure manual water valves are fully open.
• Check if water strainers on solenoid valve assembly are clogged.
• Check for obstructions inside inlet water hoses.
• Ensure solenoid valves do not leak when the valves are de-energized and the washer is powered down. • Measure coil resistance for both valves; if outside range (1000-1250 ohms at room temp.), replace solenoid valve
assembly.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM, OR FOR ERROR CODE 23:
• Replace solenoid valve assembly.
30, 31 Drain problems
• Ensure pump strainer is clean and free of debris.
• Check for obstruction inside the drain hose.
• Check pump impeller blades and bearing; if evidence of blade damage or seized bearings are present, replace the pump.
• Check electrical connections at the pump motor and harness.
• Measure pump motor resistance; if outside range (9-14 ohms at room temp.), replace the pump.
38,39 Dispenser problems
• Check for obstruction in dispenser mechanism and linkages.
• Check electrical connections at dispenser motor feedback switch and in the harness.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM:
• Replace dispenser motor assembly.
42,45, 49 Motor Drive operation above design limits
• Ensure all 4 shipping bolts have been properly removed.
• Remove all foreign objects that may be lodged between inner and outer basket.
• Look for signs of seized bearing(s) on basket and drum motor, replace components as necessary.
• Inspect condition and mounting of door gasket, replace and re-mount as necessary.
• Ensure inner basket (drum) can rotate freely.
• Replace motor drive or drum motor.
43,4A, 4B,4C, Motor Drive internal problems
4E,4F, 50,52,
53,54
• Measure AC outlet voltage, ensure correct range (102V to 132V AC).
• Check electrical connections at the drum motor, motor drive.
• Check harness integrity between main control and motor drive.
• Unplug the unit, wait 30 seconds, restart the unit.
• If the fault persists and re-appears -replace the motor drive.
problems
57,58,71 Main Control internal problems
• Unplug the unit, wait 30 seconds, re-start the unit.
• If the fault persists and re-appears -replace the main control.
60,61,63,64, DOOR LOCK assembly problems
• Check integrity of wiring and connections between main control and DOOR LOCK mechanism.
• Investigate DOOR-LOCK mechanism, check door microswitch operation, lock and unlock solenoid continuity, contact integrity;
replace DOOR LOCK mechanism if necessary.
• Replace the main control.
65 Water Level Sensor problems
• Check integrity of wiring and connections between main control and Water Level Sensor.
• Check integrity of Water Level Sensor, replace if necessary.
66,67 Water Temperature Sensor problems
• Check integrity of wiring and connections between main control and HeaterfThermistor Assembly.
• Using ohmmeter, measure Thermistor resistance; if outside expected range, replace HeaterfThermistor Assembly.
70 "Stuck" key
• Press each key. There should be mechanical "click" feedback with every press.
• Enter Service mode, use 104 test to check key operation. Press every key. Every keypress should generate audible
"beep." Press "Power" key last to avoid premature exit from t04 test.
• Separate control and control housing from the front panel; clean and remove all foreign matter and debris from keys,
front panel and control housing, re-assemble. Ensure all keys can be operated freely without "sticking."
IF ABOVE STEP DOES NOT CLEAR THE PROBLEM:
62 System Contact Failure
• Check integrity of wiring and connections, look for insulation breakdown and short circuit conditions on the harness, replace
harness if necessary.
• Check integrity and electrical connections of all loads (heater, pump, pressure switch, door lock, solenoid valves,
dispenser motor), replace respective components if necessary.
Jun 23, 2011 | General Electric WCVH6800J Front Load...
My whirlpool duet washer fills with water when not in use. How do I replace the water valve...is this the best solution?
Yes, replacing the valve assembly is the best solution to your problem. You should do it as soon as possible to avoid a flooding condition. It's pretty easy... the valve assembly is a single component that can be easy removed / replaced using simple tools. Here's how:
1. UNPLUG THE WASHING MACHINE AND TURN OFF BOTH OF YOUR WATER VALVES
2. Remove the top from the washer by removing the (3) screws from the rear face and pulling the top backward and slightly upward.
3. Unhook the electrical connections and hoses from the valve assembly
4. Remove the valve assembly by removing the (1-2) screws holding it in.
5. Buy a new valve assembly at your local appliance repair shop.
6. Reverse the removal instructions to assemble.
Good luck and happy washing!
Feb 11, 2011 | Washing Machines
Where I can buy strap for wach nemo titanium
Any Mares stockist will be able to order for you. To find your nearest supplier go to the main mares website and look up stockist for your area. Hope that helps.
Sep 16, 2010 | mares Nemo Titanium Computer Great Scuba...
Where is the egr valve on a 2005 dodge 1500 5.7L
The electronic EGR valve and solenoid assembly (3) is attached to the front of the right cylinder head (1). An exhaust gas routing tube connects the EGR valve to the intake manifold.
Disconnect electrical connector (1) from EGR solenoid (2). Remove two bolts (3) connecting EGR tube (4) to valve assembly. Remove gasket located between EGR tube flange and EGR valve assembly.
Remove two mounting bolts (2). Separate valve assembly (3) from cylinder head (1). Remove and discard metal gasket located between cylinder head and valve assembly.
The new EGR valve will come with a new metal gasket. You can reuse the smaller gasket for the metal pipe going to the egr valve as long as its not damaged.
TY for using Fixya; remember rated this post.
Apr 14, 2010 | 2005 Dodge Ram 1500
Bostitch N60 finish gun - air leaks out of the trigger when the air hose is connected
There is an oring that is probably broke in half, It is referred to as a purple o ring. You can buy the whole trigger assembly but I think that just replacing the one will get you going. Let me know and I will try and help more
Jul 29, 2009 | Stanley Tools Staple/Brad Nail Gun
Saeco incanto rapid steam leaking from under
The leak is most likely from the steam valve, you will have to either buy and replace the o-rings and the pistons in the valve or just buy a new valve assembly and replace it. Easiest solution get the new valve assembly.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Dec 01, 2008 | Aeris A1 Octo
Aeris A1 Octo Logo
191 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
