Question about Dell Inspiron 1525 Notebook
WHY BATTARY IS NOT CHARGING - Dell Inspiron 1525 Notebook
  • 182 Answers
Check your laptop battery with other similar laptop, second thing test your laptop charger is working properly, put another battery in the laptop and try , check that you are using original battery , if this not gone well better take dell service center as soon as possible and do not try to repair any thing in side your laptop yourself the battery is very dangerous product it may exploed if any short circuit happens ... thats all.....
Posted on Feb 04, 2010
  • 66 Answers
Hello mnavalgund,
there could be a variety of reasons. did u check if the battery is seated in properly.you also need to check if your power adapter is plugged in properly and you are using an original dell power adapter of the correct specifications.
ultimately,it could even be the battery has lost its basic charge that usually controls the discharge and charge cycles which means you might need to change the battery.
try taking it to a repair shop for confirmation;.
Battery drains while mowing - after about an hour I cannot engage blades if I stop mowing - I have to charge battery after each mow - Have changed battery thinking that was problem but it still continues...
Charging system on the engine is not charging, either the charging coil under the flywheel is bad, or the regulator is not working, you need to check what voltage/amps is coming out of the system, before doing thsi just check all the battary leeds are tight also the negative battary leed has a good earth at the chassis.
Jul 06, 2012 | Husqvarna 24HP 54" Yard Tractor ()
Nokia 5130c2 show charging but not charg battary and discharg battry
nokia 5130c2 show charging but not charg battary and discharg battry
Jan 09, 2011 | Cell Phones
1999 model xlr 125 battary is not charging.Head light power is not enought.battary is replaced recently.
Hello, You have to fix your charging device ( alternator). Replace the battery each time it get weak will fool you. Usually the weak parts in alternator are : carbon brush and rectifier. So you need special attention on these parts. I'll to side with you if you able to fix it yourself. But if you're is not so confident, kindly has it fixed in shop.
Nov 21, 2010 | 1999 Honda XLR 125 R
Sir, my laptop CompaqEvo610C can not charging i check my battary on other same model of Compaq it is working and good condition and give backup more then 1hour. when i put the battary in my laptop again...
Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Sep 29, 2010 | HP Compaq Evo n610c Notebook
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
May 04, 2010 | PC Chips M871G Motherboard
Will a faulty ignition switch stop the battary from charging.alternator,r/r,battary are all fine.Its a 955i triumph sprint st and the year is 1998
A guess. If you are running on "start" you might not be charging. But then, if you are running on "Start" I would suspect the starter would also be running. You didnt say this was the problem.
Is your battery going dead? Your alternator is putting out? Check the rectifier.
Sep 07, 2009 | 2000 Triumph Sprint ST
BB Rim just wont work
there is a good chance that the charging port on your phone isn't working and it is not charging the battery.
Jul 11, 2009 | RIM BlackBerry 8700c Cellular Phone
Acer aspire 4930g,charging, at first 1% to 95% the
yes you labtop battary driver may be currepted. so install fresh battary driver
Apr 29, 2009 | Acer Aspire 4930-6862 Laptop
Battary
It Prompts when Battery Low -
But U Havent Looked at it -
U Just might have put it to Cable to charge -
But it doesnt -
So Means u have to change Charger -
Be See that ur Charging socket isnt Loosened -
Then change ur charger with a Newer n Original
One -
Jan 20, 2009 | Cell Phones
CHANGE BATTARY BENQ DC 3400
baterry can not be charging . I LIVE HYDERABAD IN INDIA
Jun 24, 2008 | BenQ DC3400 Digital Camera
Dell Inspiron 1525 Notebook Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
