I have lan having 172.168.40.1. and have a 2 wify's which has to be worked with the 172.168.40.2 & 3 . what is solution to configure it .
with linksys 54g wireless router
If you are connecting to the internet, your network must use an un-assigned sub-net. You should use 192.168.1.1 - 255 with a mask of 255.255.255.0. Your router, linksys, will defaut to this. You should use dynamic addressing on the computers you want to connect, unless there is a reason that you need to use static addressing. If you need to use static addressing, you need to configure your router to only use say 192.168.1.10 - 20 for dynamic addressing. then configure your PC's to use 192.168.1.11 & 12 or anything else outside of the dynamic addressing.
I suspect your router is set for dynamic addressing and the static address that you are trying to use is in the dynamic range and your router will not see you PC's.
my base phone works fine but the second phone does not light up or work at all. I boutht them a few...
(More)
my base phone works fine but the second phone does not light up or work at all. I boutht them a few months ago and they worked fine. Went away for a few weeks and now the protable one does not work at all
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led...
(More)
Hello, i resetted a dlink dwl 2000AP wirrels acces point, and now afther set up, the wlan led doesn't light up any more
how do I open the case of a Motorola we800g? Reason - to examine the chipset to see how much flash...
(More)
how do I open the case of a Motorola we800g? Reason - to examine the chipset to see how much flash memory it has to upgrade the firmware to use wpa encryption.
I use to be able to use wireless linksys but lately received unauthorized access errors at a few...
(More)
I use to be able to use wireless linksys but lately received unauthorized access errors at a few websites and now I can't use linksys wireless, is there anyway to reopen port?
