Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
TV TURNS OFF ITSELF AND 15 SECOND LATER IT COMES
MY TV IS A 60" SONY LCD MEGA ABOUT 5 YEARS OLD. TV TURNS OFF ITSELF AND 15 SECOND LATER IT COMES BACK WITH GOOD PICTURE AND AUIDO BUT AGAIN AFTER ABOUT 15 SECOND LATER AND GOES OFF AGAIN ..IF I LEAVE THE TV ON IT WILL REPEAT THIS ALL DAY. CAN YOU HELP ME? THANKS, Kurt
  • 30 Answers
This is a Heat issue with the front sensor of the TV. Dust and Dirt block the sensor causing it to heat up faster and faster. Cleaning the lamp is extremely easy and it will get the TV working again, at least for a short while and then it will happen again. I know cause its been happening to me and it will work for about two weeks and start happening again. Sony actually has a class action lawsuit against them for this issue. Long story short here are the steps to correct the issue:
1. power down TV and disconnect from the power outlet then let sit for 30 minutes until its colled down 2. On the bottom corners of the TV (Back side) you will find a round screw that you can loosen with your fingers 3. once both screws are lose the front bottom part of the TV will pull off, there are magnets there so it will hold it in place temporarily. 4. Once the cover is removed, in the center of the TV will be a little door with another Finger screw to loosen, once off move the bar holding the door closed and remove the plate. 5. You will need an Alan wrench, the screw will be in the upper left corner, when this is loosened the screw will not fall out and you can pull out the Light fixture 6. CAREFULLY with compressed air spray the light assembly and the inside of the TV very well and then replace the light bulb. 7. Put the Door back on the front of the Light area, and assemble the rest of the TV in reverse order before testing the TV. I have done this multiple times as this is not a permanent fix but does restore life for a short period of time.
Posted on Apr 01, 2010
    Scholar:
  • 130 Answers
This could be either the lamp or ballast. I'd check the lamp first. If you've never replaced it, 5 years is a HELL of a long time for a lamp... when you replace it, you'll notice a brighter picture too. Sony uses Philips, so only buy Philips from an authorized agent. Make sure the date codes are new too, because you don't want old stock lamps.
Posted on Feb 04, 2010
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
While on the screen turns black or off for 15 seconds and comes back on.
It seems lamp in tv has reached an end of its working hours life, replace lamp in tv if it has not been replaced in last 2-3 years to solve tv problem.
Lamp replacement procedure would be written in user manual, buy Sony original lamp for good picture in tv.
Thanks.
Dec 19, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a sony Vega 55" kdf-e55a20, It is 3 years old, and now the picture and sound fade away for 10-15 sec every hour or so and comes back! Anyone knows what the problem is?
Lamp is getting weak and TV shuts off and turns on itself because of weak lamp in TV that you see picture and sound fades away for some time until TV reboots.
Replace lamp in TV to solve this issue. Lamp replacement procedure is written in user manual and its an easy work.
Please buy Sony original lamp for your Tv safety.
Thanks.
Dec 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Everything looks great then the picture goes off, the green light blinks on and off but no picture comes back..intermittandt, but will occur every 10 to 15 mins or so, have to unplug the set and then...
You have the television on sleep mode. You'll have to disengage the sleep function! Most tv have this option so that you can go ahead and snooze for a while and the tv will turn itself off!
Dec 07, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
Sony 60"
Sounds like your TV is not getting the right voltage. U need to get a power supply filter and then
all should be good. Not promising that it defo will, but everyone iknow who has this problem on a
widerange of makes and models have tryed this method and it has worked.
Let me know how you get on.
Oct 30, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
744 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
