Question about Maytag EPICz Electric Dryer
I have a Maytag Epic Z. The dryer turns on but with no heat
I have a Maytag Epic Z. The dryer turns on but with no heat, I checked the gas line and it is fine, I am on the right heat setting also, just no heat, Could it be an ignition or something?
  • 619 Answers
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Posted on Feb 05, 2010
How do I remove the light wiring harness from the front panel?
Type Maytag Epic Z into YouTube and see if the video comes up, thanks!
Jun 25, 2015 | Maytag Epic z Front Load Gas Dryer
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
My two year old maytag epic z dryer does not heat anymore
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 05, 2011 | Maytag EPICz Electric Dryer
HOOKED GAS LINE UP PLUGED IN TURNED ON AND NO HEAT. SMELLED LIKE GAS INSIDE DRYER
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
It seems like the burners are not all lighting. Maytag Epic Z gas
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryer turns on but does not heat up
the first thing to check is the ignitor .how ever there is a thermal fuse located on the exhaust duct inside the dryer that may be bad this woulld cause the unit to run and not get hot.this needs to be checked with an ohm meter for continuity there is more than one thermal fuse so check them all just to be sure.i hope this has helped.please let me now how things turned out.good luck
Jan 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Dec 17, 2008 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Maytag EPICz Electric Dryer Logo
1,403 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
