Question about Rosewill R900J 19" Flat Panel LCD Monitor
Hiya ive got a 19 inch dgim monitor which gose blank with the red power light flashing any help
  • 66 Answers
Hi carpinsy
check if the signal cable is fitted snugly at the back of the monitor and then check the same at the back of the computer.if not,it seems the computer has aboot up problem.
check the first two solutions and if it doesnt help,get back to me :)
Posted on Feb 04, 2010
Samsung TFT 19 LCD no flashing red LED continues on replaced all caps
did you check the output dc voltage of the power supply if present. if ok, then doesn't turn on the problem is with in the main board.
Oct 10, 2012 | Computers & Internet
19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Mar 24, 2010 | LG 19LG30 19 in. LCD HDTV
I have a Neovo !( inch monitor used as a security
First place to look will be for bad caps in the power supply/inverter section, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 21, 2010 | Neovo E-19 (Black) 19 inch LCD Monitor
My 19" flatscreen monitor flashes on a blank screen and the power button light flashes on and off blue, no picture.
Problem in Your monitor VGA cable no horizental or Vertical signal.So it is not active standby mode.Check signal or VGA cable on not adjust properly CPU.or any other device.May be VGA cable was broken.Replace it.If you are not replace the part so you can get help any service technician.
Dec 27, 2009 | Soyo 19" LCD Flat Panel Monitor
Pc screen
Sounds like you maybe having problems with puffy caps on the either the power board or the main board. If you can open up the monitor its easy to see, normal caps have a flat silver surface where puffy ones the surface isn't flat and it looks puffy like its pregnant.
All you would have to do is replace the capacitors with ones of the same value.
May 11, 2009 | BenQ FP71G 17" LCD Monitor
Screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Apr 16, 2009 | Computers & Internet
Flashing green light
http://www.xerox-displays.com/drivers.html
This is the link to the xerox install info. This should fix the problem. If it does not please list the CPU OS and video card you have. Before connecting the LCD monitor make sure in your display properties are set to a refresh rate of 60 hertz. You can set refresh rate by going to the control panel in windows and display settings properties.
Jan 16, 2009 | Xerox XG-91D 19" LCD Monitor
Benq t905 monitor blank
Fist check the fuse on the inverter board if it is blown replace it if not you need another inverter board as it has fried. But I looked and was unable to find a new/replacement inverter online so I wish you the best of luck
Dec 08, 2008 | BenQ T905 19" LCD Monitor
Philips 19s lcd monitor
you have to replace the capacitor in the high voltage board inside your lcd if you know how to open it
Nov 03, 2008 | Philips 190S7FS (Silver) 19 inch LCD...
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
51 people viewed this question
Top Rosewill Computers & Internet Experts
Jim Thurston
JustBeatOnIt
Level 1 Expert
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
