Question about Garden
Where is the spark plug located in a stihl 026 chainsaw (stihl chainsaw)
    Sniper:
  • 82 Answers
It is in the circled location on the image below
This came from the manual located at http://www.stihlusa.com/stihl_ownersmanuals/026_Manual.pdf
If this helps please leave feedback
Posted on Feb 04, 2010
Where is the decompression valve for stihl chain saw 026?
If it has one, it will be directly in front of the spark plug. Most 026 saws did not have one, however, an 026 Pro did.
Mar 14, 2017 | Stihl Garden
Looking for carb repair kit for stihl 026 chainsaw
Check out ebay under name of the chainsaw. The carb is either a Zama or Walbro and there are plenty kits available for less than 10 dollars.
Oct 16, 2016 | Stihl Garden
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Stihl 026 chainsaw... bogs down when giving it gas. Removed the breather and helped a little, but still bogs down under a load.
Probably need to adjust the high and low speed settings on the carburetor.
See your owners manual for location and adjustment procedures.
Apr 12, 2011 | Stihl Chainsaw 024 026 Oil Pump
I need to change the oil pump in a stihl 026 chain saw but I am not sure how to access the pump. I believe it is beneath the armature but I am not sure how to take it off. Any advice or a...
Removing the Oil Pump
  • 1
    Pull off the spark plug's rubber boot. Unscrew the spark plug with the socket wrench. Remove the spark plug and insert the piston stop tool into the hole. Remove the starter cover and turn the flywheel by hand until the piston contacts the stop tool.
  • 2
    Unscrew the brake band's cover screws with the star Allen wrench. Remove the brake spring from its anchor pin with the end of the screwdriver. Caution: this spring is under a lot of pressure and may pop out unexpectedly. Remove the brake band from its seat on the crankshaft.
  • 3
    Remove the E-clip that holds the washer, sprocket and clutch drum to the crankcase. Pull them off the crankshaft. Unscrew the clutch's bolt with the socket wrench. Loosen the bolt clockwise and remove from the crankshaft. Pull off the washer. Remove the clutch shoes and the clutch spring.
  • 4
    Twist the worm and drive spring clockwise and remove them from the crankshaft. Unscrew the oil pump's mounting screws. Take the oil pump off its seat and remove from the crankshaft. Remove the bottom washer.
  • 5
    Disassemble the oil pump. Knock out the spring pin on the bottom with a punch. Pull the bottom control bolt from its hole and remove the O-rings. Pull the end plug off housing and remove the pump piston, spring and washer.
Read more: How to Repair the Oiler on a Stihl Chainsaw ' eHow.com http://www.ehow.com/how_6515266_repair-oiler-stihl-chainsaw.html#ixzz1H62BeTAW
Mar 19, 2011 | Stihl Chainsaw 024 026 Oil Pump
I need a parts manual for a stihl 026 chainsaw
Parts list here http://bricomeca.free.fr/Stihl/stihl%20026%20IPL.pdf
if this helps please leave feedback
Feb 04, 2010 | Garden
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
258 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
