Question about Dishwashers
Is not cleaning the glasses - Dishwashers
If you have hard water this is always a problem, best solution i've found is a product you can buy at Wal-mart called Lemi-shine. Just add a little in each detergent dispenser pockets every load. works great.
Posted on Feb 04, 2010
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
Tip
Cleaning your inside scanner glass
Actually it's a very simple procedure!
Read this entire comment first...then start your procedures!
Disconnect the power cord, disconnect the USB cable, remove the top cover cable from the base by unscrewing the two plastic knobs, lift the top cover straight up. Place the top cover in a safe place.
On a clean, flat surface, turn the base upside down. On both ends you will find a total of four (4) black phillips head screws. Carefully unscrew these four screws and place aside. Carefully lift up the base and the top glass will separate from the base. Set the base aside. You have now exposed the inside glass for cleaning! It's that simple!!! Clean the glass by using a streak-free glass cleaner. Don't spray the glass, rather, lightly spray a clean soft lint free glass cleaning cloth, then wipe the glass. Don't press hard! Use good common sense1 There, you've now cleaned the interior glass. Reverse the procedure and you are finished. Wasn't that simple??
on Feb 15, 2009 | HP Scanjet G4050 Flatbed Scanner
How do you clean inbetween the oven glass door?
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
Now you have a clean ove glass again...
heatman101
Nov 16, 2010 | Microwave Ovens
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Platen glass dirty clean platen glass
user mode
common settings
additional functions
13. adf dirty error
display(default) / do not display
Sep 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
We are using a Canon DR-9080C and we keep getting black lines through the documents we scan in and we've cleaned the machine. What can we do to remedy this problem
You want to run (2) tests:
1. Make a copy using a clean, plain sheet of paper from the regular glass top. If it copies clean then:
2. Make a copy from the feed unit. If that is where the streaks are then you just need to clean the scanner glass (this is the small thin glass next the flat, copy glass. Use glass cleaner and a COTTON wipe. You may have to clean it a couple of times to get the residue off the glass. Each time you clean, make a copy.
May 30, 2008 | Office Equipment & Supplies
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
Owen Barnes
