Question about Sharp CD-BA200 CD Shelf System
Sharp CP-BP2000 speakers. How do I connect these to an amp?
I bought a pair of second hand speakers. Sharp model no. CP-BP2000. They have two double wires coming out of the back, top ones blue/black and bottom ones red/black. How do I connect these to an amp?
ginko
  • 19396 Answers
SOURCE: Hi, I bought a second
Try this reset:
Pressing the @, 1, and 0 keys together at the same will cause your phone to save all data and reset
Posted on Jul 22, 2008
  • 8457 Answers
SOURCE: my sharp lcd tv has red & blue pixels accross
Ur main video backlight board is dead,must be replaced.
Posted on Oct 20, 2009
  • 567 Answers
SOURCE: I have been given an old Sharp music center but
l means left r means right connect speaker wires by phono sockets or if no phono sockets then the wires go direct into the colour sockets red to red etc
Posted on Jun 08, 2010
eagle338
  • 4889 Answers
SOURCE: I was given 2 -
You have probably connected it using video only HDMI cable(its called DVI). You may want to get a HDMI connector so that you can obtain sound as well. Your brother was probably using external speakers along with the DVI cable.
Posted on Oct 18, 2010
dunnbiker
  • 8546 Answers
SOURCE: I got my hands of
Which is it 9860 or 9800? (No web search hits for the 9800).
JVD Tuner?
The RCA jacks on any amp so-equipped are for any external Line Level source like a tuner.
In any 'connection' question there are at least two participants and specific answers require specific details about all joined equipment.
Type carefully if you want good answers.
Posted on Sep 24, 2011
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
How to wire the tuner and amp what wires do i need to get it to work
In most cases, you need a pair of Red/White RCA cables. Connect one set of ends (1 red + 1 white) to the external tuner's output and the other (white + red) to the input on the Amp.
Then you need double stranded wire to connect the speakers to the amp. one x double stranded wire for each speaker. You can use electrical cord from the hardware store (e.g. 18 gauge wire) or you can buy some speaker wire (16 to 20 gauge - use lower number wire (thicker) for higher power amp). 16 to 18 gauge wire for a 100 watt per channel amp if your speakers are less than 15 feet from the amp (wires are less than 15 feet long). If longer than 15 feet, use the 16 gauge wire. You can use 18 gauge for most anything else.
Jun 20, 2011 | Kenwood Audio Players & Recorders
I have a pair of pioneer ts A-6987 connected through an amplifier and pioneer cd player..i noticed today that the left speaker's cone woofer stopped working whereas the its producing voice but if very low...
double check the ratings on the speakers and amp. speakers that size don't usually require an amp. compare the wattage and resistance numbers, if you haven't fried an amp, you may have blown a speaker. another possibility is a short in the channel. check wiring connections.
Jan 29, 2011 | Pioneer TS-A6987 Car Speaker
Hi i have just bought a alpine dvd headunit the 105r and it only has 1 phono sub output and not the left and right phono output how do i connect my amp to this
it has 3 pairs of rca outputs, one pair for the front, one for the rear, and another for the subwoofer. the other sub preamp output is not needed to run to your amplifier.
For better sound quality, buy an RCA Y splitter cable (single male connection to double female connections), and run your regular pair of rca cables to the amp.
Nov 03, 2010 | Alpine Car Audio & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How to fix rockwood 10 in. 800w sub?
i would double check your connections also any fuses on the amp i have blown a few fuses on my amp haven't checked into the main reason for that to happen but its common if you don't have a big enough amp... assuming that the amp is getting overloaded. I would say you need a bigger amp like 1600watt or 1800watt
Jul 30, 2009 | Car Audio & Video
I bought some second hand Technics SB HD 501 speakers, & noticed some note on the back that said something about 'risk of fire if not used with proper units etc'. is this true? They have two speaker...
Don't sweat it unless you're going to chain them to an electric arc wielder or something like that. I think your amp would cut out or the sound would get really bad long before a fire started. ;-)
Any typical amplifier that is NOT driven beyond it's capabilities will do just fine. Just make sure the impedance requirements of the amp and the speakers are in the same ballpark. Speakers being too low is possibly a problem but not dangerous, too high is no biggie.
May 13, 2009 | Audio Players & Recorders
Sharp DP2500 speaker bus diagram
Hi..have you gotten an answer for this question...I just googled this model number..and about the second one down is the factory service manual...for the model you and I have...there is a way to go inside and solder wire to each speaker leg to make it work that way without the special plastic connector that was the original..
Apr 05, 2008 | Sharp HTDP2500 System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
CDC-R304
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Nov 08, 2007 | Aiwa CDC-X204 CD Player
Sharp CD-BA200 CD Shelf System Logo
382 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
