Question about Syntax OLEVIA LT20HV 20 in. LCD Television
It displays for a second, then goes black!
It displays for a second, then the screen goes black but the power light stays green
    Problem Solver:
  • 12 Answers
If you still have audio it looks like an inverter problem.
Posted on Feb 04, 2010
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Syntax OLEVIA LT20HV 20 in. LCD Television Logo
151 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
