Question about Sony MHC-RXD5 Shelf System
Sony HCD-RXD5- When i turn on the tape deck function it clicks a few times and power turns off .
bmwrider
  • 215 Answers
SOURCE: Tape Deck
Really simple one this. You have a slipping belt. Don't try to use any more tapes in it, you end up chewing them up. I change all my belts in my decks every 2 years due to the extreme heat we have here. Unless you know how to strip the unit and can get hold of the correct belt I'm afraid it's a repair shop job. BMW To give you some idea of price I charge $50 for a complete service, alignment and belt change.
Posted on May 22, 2006
SOURCE: Clicking sound in tape deck
All Aiwas  are prone to this problem.  The doors are a real pain and easily give up the ghost.  I have 2, both probmatic in this direction.
I have spoken to others about this problem. Seems no easy fix.
Have you in your case, tried leaving and old tape in the tape part of your  unit . The noise you hear, usually starts when tape unit area doors are about to pack a wobbly. Unless under warrenty, proberly,
not worth getting fixed.    It seems something gets weak in the activation part and get a mind of its own.  Very common after about 3 yrs of ownership.  All the best: jamz
Posted on Oct 25, 2007
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
  • 221 Answers
SOURCE: DSR 25
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
Posted on Jun 16, 2008
SOURCE: Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Posted on Jul 11, 2008
How to repair SONY HCD-ZUX10D DVD DECK RECEIVER always display EJECT and then STANDBY ?
https://community.sony.co.uk/t5/home-cinema-projectors-players/how-to-repair-sony-hcd-zux10d-dvd-deck-receiver-always-display/td-p/2295791
Aug 21, 2017 | Sony Audio Players & Recorders
My sony mhc-bx7 makes a strange clicking noise 3 times when you turn it on and it then says tape b on screen then says eject and powers down. what is the fault and can i fix it?
Dual cassette deck are nothing but trouble, but on occasion they can be made to work a little longer. Maybe lose belts or the most common thing is the grease is all dried up. It requires the cleaning off and application of new better grade grease. The problem is the mechanism has to come apart and make sure it is aligned when put together- this can take 3 hours.
Aug 27, 2016 | Sony Audio Players & Recorders
There a problem with the power to the deck it turns on for a few seconds then shuts off. There is a tape stuck in the deck that needs to be taken out before I can send it off to get fixed. Is there...
For this type of problem.first u need to take the tape out from the Compartment.open the unit also upper compartment unit.Use DC power supply to Main Cam motor.then Ur power problem be not there any more
Jan 18, 2011 | Sony HVR-M25U HDV VCR
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
Aug 24, 2010 | Audio Players & Recorders
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Sony HCD-GRX40AV Cassette Player Belt Layout Diagram Required
Hi , i have just spent half of yesterday trying to replace 4 belts in a sony twin player , you wont need a manual just take the cover off and remove the white plastic cover off the cassette unit at the front , after you remove this cover all will be revealed , my opinion is get a repair person to do it for you as it is really fiddly and time consuming plus you have to buy the right belts anyway , hope this helps ..
May 24, 2009 | Audio Players & Recorders
Sony TC-WE475 problem when taping A to B, B is not recording. Heads turn but no sound.
Hey there,
Next time you have a few minutes, open the B side of the tape deck and look at the actual tape head- if it is dirty, you can clean it using cotton swabs and 80% isopropyl alcohol. (Higher than 80% is actually better, because it has less water in it)
Let me know if this helps your problem,
HortonA!
Mar 22, 2009 | Sony Audio Players & Recorders
Sony Cassette TC-WR535 BELT REPLACEMENT
Unit may have defective idler or gear. Have serviced
Aug 05, 2008 | Sony CASSETTE DECK Single Dual Cassette...
238 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
