I have a hotpoint washer/dryer model WD715 and it is not draining properly. It is displaying "check outlet pipes" and also its flashing up "E 15"
  • 767 Answers
You will have to unclog the pump. Unplugg the machine and tip it forward you should see the black hose that comes from the pump to the outlet. Take this hose off by loosening the clamp then you should be able to see that the pump is clogged. They sometimes get a small sock or lint that pluggs the up. Clear the clogg and the machine should work normal again usuall will take 15-20 min. to fix.
Posted on Feb 04, 2010
Hotpoint wd440 washer/dryer. 1st problem was it wouldn't drain so I cleared the pipe. Now the machine 'wash' light flashes during a wash. The washing machine doesn't seem to hold the water...
Make sure that the outlet of the pipe is at least as high above the floor as the top of the machine. If it is lower than the level of the water, it will just drain - there is no shut-off valve to stop it from doing this. Please rate this answer.
Jun 17, 2011 | Hotpoint Washing Machines
Fault code F05
If Hotpoint or Creda,
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Jan 18, 2010 | Hotpoint Aquarius WD640 Front Load...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Hi hotpoint 7kg washing machine ultima digit washes fine and spins etc but i keep getting f05 flashing on display what do i do
Hi there usually the FO5 Problem is pump draining problem, check the U Bend under your sink for blockages also the outlet pipe for blockages, you may even need to take of the front lower panel and you should find a small pipe and you can clear and drain water from that also and clear of any bits. hope this helps
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Waste hose connection hotpoint wd440g
Have you checked the filter? This can be found at the large end of the pipe. It is secured with a large jubilee clip.
Thankyou for using Fixya.
Feb 12, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint WD440 1400 Spin
There has been an unbalanced load and the machine could not spin
(see ‘Automatic Features’, Starting and Programmes).
Has the drain hose been installed correctly (see Installation)?
Are the drain hose, standpipe or undersink connections blocked?
Has ‘Rinse Hold’ option been selected? If so press the Rinse Hold button
drain hose make sure there are no kinks and the end is over the top of washer to drain this ensures that there is no back flush with drain pipe
clean the dispenser drawer regularly
Clean and dry the dispenser
drawer, syphons, grate and
fabric conditioner exit channel
(A). Also regularly clean the
outlet pipe area
Never force the machine door: this could damage
the safety lock mechanism designed to prevent
any accidental opening
May 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Oct 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
