Question about GE JGBP86SEKSS Stainless Steel Gas Kitchen Range
Oven AND broiler do not work but self-clean does
Wife went to use the oven today (used it yesterday) and it would not light. Turns out the broiler doesn't light either. Neither igniter was glowing. However, in trying to narrow down the problem we tried the self-clean mode. Self-cleaning works fine with both burners (broiler and oven) working well. Any suggestions?
  • 10 more comments
  • larryableguy Feb 21, 2008
    That raises one question and perhaps two:
    1. Where are the fuses?, and
    2. If the fuses are in the top panel, how does one remove or gain access to the top panel? Again, model #JGBP86AEA2AA.
    First link troubleshooting was of no help. I had checked the gas valve earlier. It was wide open. Besides, if the gas valve was closed then the self-clean mode would not have worked I don't believe the second link applies either. Both igniters (bake and broil) seem fine for the same reason (self-clean mode works). Top burners work well.
  • larryableguy Feb 22, 2008
    None of the situations on that site apply. Neither the oven nor the broiler work (two separate igniters) yet both igniters work fine in self-clean mode. Based on what is actually happening, it is not an igniter problem and it is not a gas valve problem but it is something that is common to both the oven and broiler. I am not sure what that might be other than the ERC.
    clock works fine. timer works fine. all burners work fine. everything on the "brains" panel seems to be working except "broil" and "bake". However, nothing "clicks" after setting the temperature and hitting "start". thanks for your efforts.
  • larryableguy Feb 25, 2008
  • larryableguy Mar 06, 2008
    No one has responded since Feb. 22. Please see response of Feb. 25.
    I can find no reference anywhere to a "switch". What "switch" are you referring to and where might it be? Thanks.
  • larryableguy Mar 07, 2008
    To summarize:
    GE XL44 Model #JGBP86AEA2AA, serial HV226529P. Top burners work fine. Self-clean works fine so igniters are OK and gas valves are open. Neither the broiler nor oven work: when you hit "Bake", punch in a temperature, and hit "Start" or when you hit "Broil" and hit "Start". In both cases you hear one click after hitting start but nothing else happens. When you hit "Self-Clean" and then "Start", everything works fine. Same "Start" button in all three cases.
  • larryableguy Mar 08, 2008
    To summarize:
    Sweet_rascal, assuming it is a welded relay (and that sounds pretty good), does that mean that the electronic range control needs to be replaced or is there another "fix"? Thanks.
    New update: Ran the self-clean cycle again. Only the top igniter fired up (the one in the broiler). The bottom igniter (oven) did not heat up. Is this looking like an oven igniter problem even though the broiler does not work by itself? Thanks.
  • Anonymous Mar 17, 2014
    we hadn't used it turned it off but try the oven and is stuck in clean mode. Is there a fix?
    Brigadier General:
  • 3,614 Answers
If not you may have low supply pressure to your range or the regulator may be limiting the gas flow. Also, I have a wolf gas range and it takes 30 minutes to heat to 350 as well, haven't timed it to 400. Has it always taken that long? Another thing to check is the door seal. If its not sealing it could cause a long preheat. If the door seal is smashed flat and/or not soft it needs replaced.
Posted on Mar 08, 2008
  • micromaster
    micromaster Mar 09, 2008
    There's 2 common problem with the one like your/s. First if the burner does not fired up it could possibly the pressure of gas or no gas is coming out into the burner hole/s that why it's not fire-up. Second when the gas is present and the amount of pressure is OK when you switch on the ignition and never give a flame into the burner, this can be possibly that the ignition doesn't have that enough supply of electric to ignite the gas..
    .i..e possible that the ignition pin have not align to the burner holes where the gas air flow, and for the #2 the side of the burn have a dust or a corrosion that limit the gas came out to that hole where the ignition pin is pointing, for the #3 is the ignition key have to replace a new one.
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Mar 08, 2008
    You've got a welded closed relay on the control board, shouldn't be
    hard to track down once you access the schematic which should be folded
    up behind the control panel.
  • 104 Answers
Good day, i suggest to check all inside wiring and switch. thanks
Posted on Mar 06, 2008
  • 2,336 Answers
Check this site for more info.
Posted on Feb 21, 2008
  • Jaime Hernandez Feb 22, 2008
    If you have tryed everything in regards to the igniters, gas valve and still does not work.
    Next step should be to check the electrical parts.
    Are you getting power to the appliance?
    Is the clock or timer working properly?
    Do you hear the relays clicking?
    Master:
  • 788 Answers
Check the fuses
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Ge electric broiler inoperative
Link to manual
check page 22 for self cleaning oven
(door is latched )
make sure clock and timer are operative
Dec 20, 2007 | Ovens
Wfg361lvs oven clicks 1 times, lights and then clicks three more times and turns off.
manually check the burner and the gas jet area for blockage that would prevent lightup.. the safety is kicking in to prevent gas explosion..
Jan 12, 2014 | Whirlpool WFG361LVS Stainless Steel Gas...
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
Two nights ago my wife tried to run the self cleaning cycle on our Kenmore range. Unknown to her mice had nested under the burner plate. Dog food that they had deposited there began to burn, but no...
ok but only because it christmas , the mice must have chewed one ot the wires. re ck and i think you will find it . ck the main valve where the gas comes in as that is where they did. they may have get in the back panel ( clock area and damaged wiring . / ck carefully and i think you'l find it . **** .. have a good christmas .. ****
Dec 24, 2009 | Kitchen Ranges
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
GE JGBP86SEKSS Stainless Steel Gas Kitchen Range Logo
381 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
