Computers & Internet Logo
Posted on Feb 04, 2010
I have a Scan Snap S1500 it will not allow me to print due to integer needing to be between 1 - 0 It does not allow me to imput these numbers and comes up with same message. Can you help please Bob
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2433
Points
15
Pls tell me sony sound forge 9.0 serial number
Improper fraction to mixed number
You do the operation to get a decimal number.
Isolate the integer part (to the left of the decimal point)
Convert the non integer part (decimal part) into a fraction.
Write the result as (integer part) (fraction part)
3/2=1.5
Integer part is 1, decimal part is 0.5
0.5 as a fraction is 1/2
3/2= 1 1/2
1helpful
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
public static void main(String[] args)
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
How do I program the calculator to read random numbers 1-50?
The post answer the question concerning how to generate random integers. The example given is for rolling a dice. I am inserting the modification that treats your case at the end.
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates keypresses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
To generate random number between 1 and 50
Int(Ran#×50)+1
2helpful
3answers
What is the meaning of whole numbers?
no decimals (1.5, .56) no fractions (1/2, 1 3/4)
whole numbers are just whole numbers
1, 2, 3 and on 9,10,11 .....
not
1.5, 2.5, 2.356
1 1/5, 2 2/6,3 1/5
Generating radom itegers
Ran#×6
Int(Ran#×6)
Int(Ran#×6)+1
1helpful
Ran#
A random number generator exists on this calculator. It is accessible in RUN or PGRM modes by pressing the OPTN key. If you don not see a tab PROB at the bottom of screen, press the rightmost key to move to next page.
Anyway, RAND# generates a real number between 0 and 1.
For other numbers read on.
Ran#×6
Int(Ran#×6)
[OPTN].......(NUM) [F2] to access the (Int)
Int(Ran#×6)+1
The @ sign
The picture link didn't work for me... and seeing as you asked in August of 2008, I'm certain you don't need this answer, but here you go...
According to the TI-89 Guidebook:
This notation indicates an “arbitrary integer” that represents any integer. When an arbitrary integer occurs multiple times in the same session, each occurrence is numbered consecutively. After it reaches 255, arbitrary integer consecutive numbering restarts at @n0.
This notation indicates an “arbitrary constant” that represents any integer. When an arbitrary constant occurs multiple times in the same session, each occurrence is numbered consecutively. After it reaches 255, arbitrary integer consecutive numbering restarts at @0.
So it's the same concept, just a little different. It all depends if it is shown as @n1 or @1 where 1 can be any integer to 255
Hope this helps
2answers
Help me
this the code for your problem. by the way this for vb6.0
Sub CountCharacters(Text As String)
Dim iVowel As Integer
Dim iCons As Integer
Dim iNum As Integer
Dim iSpace As Integer
Dim iOther As Integer
Dim cnt As Integer
Dim sChar As String
For cnt = 1 To Len(Text)
sChar = LCase(Mid(Text, cnt, 1))
Select Case sChar
Case "a", "e", "i", "o", "u" ' And sometimes "y"?
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
' Includes the first case, but VB matches the first case and stops
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
Case " ", vbTab, vbLf
' Space characters
' Not including vbCr as this will likely be dealing with Windows text
' and I only want to match one character for a newline
iSpace = iSpace + 1
Case Else
If sChar <> vbCr Then iOther = iOther + 1
End Select
Next cnt
Debug.Print "Text: " & Text
Debug.Print "Vowels: " & CStr(iVowel)
Debug.Print "Consonants: " & CStr(iCons)
Debug.Print "Numbers: " & CStr(iNum)
Debug.Print "Space characters: " & CStr(iSpace)
Debug.Print "Other: " & CStr(iOther)
End Sub
Help me
Dim iNum As Integer
Dim cnt As Integer
Dim sChar As String
Select Case sChar
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
' Space characters
iSpace = iSpace + 1
Case Else
End Select
Next cnt
End Sub
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
