Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Central heating programmer
Hi
i have no lcd display on my timer, can you, help
  • 3 more comments
  • liz 62 Feb 20, 2008
    no nothing is working it appears to be dead!!
    no everything else is working, and there doesnt seem to be a fuse
    thanks
    Hi, no there is nothing there at all, everything else in the house is working except this, thanks for your help
  • Anonymous May 11, 2008
    The digital display on the programmer does not display anything and we are not able to switch the heating on using the programmer. Have checked the fuse but everything else works
    the digital display on my Honeywell programmer is not working. Everything else works fine.
  • 123 Answers
Is the buttons still working, eg, boost, on/off etc? or is the heating not working?
If so the LCD/Control panel may have lost power, this usually a switch/or fuse that may have been accidently powered of or blown
Posted on Feb 20, 2008
  • 1 more comment
  • Steve Martyn
    Steve Martyn Feb 20, 2008
    is there a trip fuse in your fuseboard that may have tripped, is anything else, sockets etc not working?
    is the a fuse connected to the unit?
  • Steve Martyn
    check your mains fuse box to see if anything is tripped. Is there a fuse beside the timer?
  • Steve Martyn
    you may need to call some company that would be able to test it properly, sorry i cant advise anymore, good luck...
How do i set the heating/hot water timer on the LP112-24 acl controler ?
The instructions are available here: http://www.draytoncontrols.co.uk/Complete_LP_Installation_User_Instructions.aspx I hope I have been of help but please do not hesitate to ask if you have any further questions. Set the central heating Press the YES button, and the display will ask 'SET CH PROG?'. Press YES and you'll see ON1, the start of your first central heating period. Adjust it in 1-minute steps using the - and + buttons. If the - and + buttons are held down, the time changes in 10-minute steps. Press SET?, and you'll see OFF1, the end of your first central heating period. Adjust this in the same way, press SET?, then repeat the procedure for ON2, OFF2, ON3 and OFF3. Set the hot water When you press SET? after setting OFF3 for the central heating, the display will ask 'SET HW PROG?'. Press YES, then set your times in the same way. Remember, in this mode you can have different times to your central heating if you wish. When you press SET? after setting OFF3 for the hot water, the programmer will return to normal operation.
Feb 19, 2011 | Heating & Cooling
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
The timer my missus had,broke down (st6100c)
Hi do you have the make and model of central heating boiler
Aug 11, 2009 | Honeywell Programmable Thermostat Heater
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
I've a problem with my central heating, I've changed my central heating programmer to a drayton lp522. My heating is constantly on. The only way that I am able to turn it of is with the thermostat when I...
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Dec 03, 2008 | Water Heaters
Heating & Cooling Logo
217 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
