Question about Casio G-Shock G100-1BV Wrist Watch for Men
I can not include (switch on) hour alarm, do this model of he (it) own ? G100 1BV
    President:
  • 2,501 Answers
I suggest that you read the instructions for your watch.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download you
Posted on Feb 07, 2010
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Tip
    TGHK watch instructions
    This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
    on Mar 18, 2010 | Watches
    Switch on hourly alarm
    Hi dalutadvd,
    you can check the manual of the G-shock G2600 model on this site so you will know how to switch the alarm of your watch...
    http://mygshock.com/casio-watch-manuals/2600-1.png
    hope it helps...
    Jun 26, 2012 | Casio G-Shock G2600 watch
    My watch beeps every hour & alarms every 3 hours. How do I remove this?
    Adidas do not list their watch instructions by model but give a complete list of all the various models they make, including a picture of the watch face.
    If you go to http://www.adidas.com/campaigns/watches_fw07/content/index.asp?strCountry_adidascom=us you can click on the language and arrive at a list which you can scroll down until you find the instructions that apply to you watch.
    (I suspect that you press the mode button (8 O'clock) to arrive at alarm (AL?) and the press the one at 4 O'clockto disable it but to be sure you need to find the correct instructions) Good luck!
    Feb 16, 2011 | Adidas Candy Digital watch
    I have a xonix watch that chimes every hour, how do I stop this?
    I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
    Sep 27, 2010 | Watches
    Setting Armitron Watch model WR330
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
    Mar 14, 2010 | Watches
    Press button C (bottom right) until you "SIG" is displayed. Then press button "D"to toggle "OFF" to "ON".
    I have taken this from the instructions for my Casio watch (different model) but I think it is likely to be the same.
    If this doesn't work, you can download instructions for your watch by going to "Casio.com", selecting "support", then "manuals" then "watches"; accept terms and on the next page select "watch manual archive"
    Enter the required number off your watch and click on "search".
    Feb 04, 2010 | Casio G-Shock G100-1BV Wrist Watch
    I have a Timex T42351 tachymeter chrono alarm wristwatch which needs the time adjusting. Unfortunately, only the hour hand moves (also altering the date). I need to adjust the minutes. How do i go about...
    This watch has a cool feature that allows you to change only the hour if you are changing time zones. But if you want to change the minutes as well, then pull the crown out farther. You'll find that it has four positions: Normal, pulled out one notch, pulled out two notches, and pressed in to turn on the light.
    Cool.
    As long as we're at it, notice the crown in the four o'clock position also has three positions. In: set alarm. One notch out activates an alarm including the hour and minutes. Two notches out only activates the minute setting, so you don't have to move the hour hand all the way around.
    Also cool.
    Dec 22, 2008 | Timex T42351 watch
    Alarm goes off at midnight & repeats for half hour, and not set
    what you have to do is
    1. press the mode button until you get to the setting that has "AL" at the bottom right.
    2. then you press the "receive" button to switch between the four alarms.
    3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
    4. repeat step fout for all of the alarms, and the problem should be fixed.
    Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Casio G-Shock G100-1BV Wrist Watch for Men Logo
    60 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
