Question about Fuji FinePix F810 Digital Camera
Cannot install my finepix f810 onto my computer, correctly.
I have just upgraded to windows 7, but cannot install my camera correctly. I have downloaded the recommended driver from fuji, but still can't get any photographs on my computer. I was previously using windows xp, and had no problems. Can someone please help. Thank you.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free program Picasa ( http://picasa.google.com ).
Posted on Apr 05, 2011
Can I get my Finepix software to run on Windows 8?
Consider NOT using the FinePix software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you an use any photo cataloging program such as Windows Photo Gallery or Picasa.
Oct 30, 2012 | FUJIFILM Cameras
Fuji finepix f810 flash wont pop up when button pressed
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
May 22, 2011 | Fuji FinePix F810 Digital Camera
Problems downloading from camera using windows 7 - error message say windows XP required - is it possibel to upgrade software to be compatible with windows 7
If your OS is Win7 64 bit, then incompatibility must be occur because Windows XP use 32bit Operating System and driver software usually only special for each OS (x32 or x64). About upgrading the software, how will you upgrade while you can't even install the basic software in your PC ? The choice you have is find another driver that compatible with your OS, you can search via Google, and I hope you are lucky enough to get it available or even free to download.
If you still want to upgrade, then the Windows7 is the one to be upgraded so you can use XP Mode system. You must have Windows 7 Professional, Enterprise, or Ultimate to run Windows XP Mode. You can visit microsoft.com for details.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Fuji FinePix F810 Digital Camera
Fuji Finepix Z won't load photos onto my computer
I have recently upgraded to windows 7 and now am unable to upload my photos from my finepix110w camera. I have re installed the software, but it still doesn't recognise the camera when attached.
Dec 24, 2008 | Cameras
Photos
Hi
I only use WINDOWS so this solution is not applicable for MAC or LINUX
1) Connect cable to camera ( camera is turned off). There is a picture on page 131 of the manual
2) Connect other end of cable to PC ( PC should already be on)
3) Turn camera on by pressing PLAY button on the back and holding until camera starts. This method of turning on and off means the lens will not operate and so is ideal for when connecting to computer. Your camera LCD should like up and it should display "USB" on a white background.
4) If you have not installed the drivers (from the installation CD-ROM) then windows will try to install the software and depending on the WINDOWS version then you may be prompted to insert the CD-ROM.
5) Once drivers are installed you should get a confirmation that hardware is ready for use. If you have already installed the drivers and Finepix viewer then finepix viewer should open automatically. Finepix crashes on my PC (Windows VISTA is rubbish!) so I just use windows explorer.
6) The camera appears as an external drive in windows exploere. Look for FinePix S8000fd. Expand the folder contents until you get to a folder called 100_FUJI. The pictures from the camera are in here.
7) Use copy and paste to copy from Camera to a folder of your choice. I have a folder called "Photos" and other folders inside it arranged by date.
8) When you have finished you must turn the camera off before disconnecting. Press and hold the PLAY button until LCD swithces off and disconnect cable from PC then camera
Hope this helps
Jun 15, 2008 | Fuji FinePix S8000fd Digital Camera
Installation and Usage Tips for the DiMAGE 7 Optional Enhancement Upgrade:
Taken from the DiMAGE 7 Upgrade Software Installation Pamphlet… Power Supply during Update: When performing the software update, please use a set of fully charged NI-MH (nickel hydrogen) batteries or the AC Adapter AC-1L or AC-2L (sold separately). When using the AC Adapter, be sure not to inadvertently disconnect the camera during the software updating procedure, otherwise the camera may be permanently damaged. Amendment to the DiMAGE 7 Upgrade Software manual… (Located on an insertion card within Upgrade Kit and Upgrade Firmware boxes) For Windows XP users: Do not copy the dsc.app and ram.bin files directly from the CD-ROM to the CF card or the upgrade will not be executed correctly. First copy these two files onto the computer’s hard drive or desktop, and then copy them into the CF card. After upgrading: When the camera is turned to the playback mode, the no-image message appears and the images taken before the upgrade are not displayed. These images were placed in a folder with names ending in MLT03, the upgraded camera places images in folders ending in MLT14, see CompactFlash card folder organization in the DiMAGE 7 manual. To view images taken before the upgrade, select the appropriate folder in the custom 1 section of the setup menu. Refer to DiMAGE 7 manual for a description of this function. When using autofocus with the wide focus frame, the live image may freeze for an instant as the AF system determines the focus. This is because autofocus speed is increased
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Fuji FinePix F810 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
