Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Mazda 2ooocc turbo diesel
White smoke on start up using oil dealer cant find problem emmision test ok
  • jock 60 Feb 23, 2008
    engine milelage 48000 used one litre oil in 12000 miles diesel turbo just out off warrenty by 2 months tested by main dealer result engine ok exaust emision ok but still lots of smoke on initial start up stops after 2 minutes running
    Scholar:
  • 163 Answers
Valve seals if its only on start up generally.. What motor? And how much oil loss per mileage?
Posted on Feb 20, 2008
Isuzu 3000/Diesel/Turbo/Wizard, I can see a bit of Oil coming from Intake/ThroughBody direct to the Turbo & there also a White Smoke from the exhaust + Misfiring and the car is not pooling as uses to be......
Turbo shaft oil seal is probably leaking a little bit, though not ideal it isn't unusual and not particularly detrimental (mostly).
The white smoke indicates either a water or coolant ingress into the combustion chamber or an excess fuel condition. A small fuel excess usually results in a increasingly dark smoke, grey to sooty black and sometimes an increased diesel knock but large amounts of excess fuel results in white smoke which is unburned fuel.
This is often the result when the fuel injectors are sticking, dribbling, leaking and misfiring could also be a further symptom. Bad starting could be caused by several things needing attention but poor injector performance can be a major factor.
I suggest you have the injectors removed and tested.
Jul 18, 2017 | Isuzu Cars & Trucks
I have a mazda mpv 2006 2.3l turbo from japan.2 months of using the car its smoking and oil level dropping ever day
If the vehicle has a diesel engine and it starts with black smoke that clears you should put some injector cleaner in the fuel tank, a couple of treatments should clean the injectors.
If the smoke is grey/white perhaps you should have the engine checked for issues.
If the vehicle has a petrol engine maybe the valves need some attention.
Ideally you should have the people who supplied you with the vehicle take a look at it . The problem wit himports is that some elements of a vehicle need modification to run correctly, this sounds as though something more serious may be ammiss
The oil level is reducing quickly, that needs investigation.
I would say that the person who supplied you with the vehicle needs to take a very close look at the engine.
GOOD LUCK WITH IT
Jul 03, 2015 | Mazda Cars & Trucks
Ssangyong musso. 2005 2.9 diesel. turbo. hard to
turbo seal is blown allowing oil into air intake charge-white/blue smoke=oil- black smoke=rich fuel mix-replace turbo-cheers Denny
Nov 01, 2013 | Cars & Trucks
Saab 9-3 diesel 120, My turbo charger is load and whe given a bit of throttle 2 overtake ect.. lots of black smoke piles out the back and sometimes e turbo will stop workin untill u tur the car of and back...
The turbo will not cause black smoke. White smoke, yes, if its passing oil into the engine, but not black.
First check that the air intake and filter is not blocked, check that the air hoses from the turbo and intercooler are not collapsing when given throttle.if thats ok, then get the injectors tested, if they are ok then you need to get the injection pump serviced. Black smoke is a result of overfuelling, either by the poor dispersal of fuel from the injectors or the pump, or blockage of air into the engine on the intake system.
Hope that helps
Feb 16, 2010 | Saab 9 3 Cars & Trucks
2005 Ford F350 SuperDuty 6.0 litre Diesel. Truck was very sluggish to accelerate and little or no boost showing on turbo pressure gauge. Next morning, it started fine, but when put in gear would quit and...
well the question is where did the coolant go. if it didnt leak out it must have went out the pipe. As you stated, white smoke, white smoke is coolant. You definately need to get this to the shop. You cannot drive it this way or further damage will occur.
Nov 21, 2009 | 2005 Ford F 350 Super Duty
Have Mazda bravo B2600 4WD ,has white smoke & oil from exhaust. Running rough as if on 3 cylinder
You dont say weather its a petrol or diesel engine as there a slight differance in the answer and if a turbo on a diesel thats even more of a differance, but taking it a petrol .
Well to start with the white smoke Isent smoke its water and after going through the engine it turns into Steam and thats what you see..
Running on 3 clyinders is caused through 1 cylinder isent working as a engine should and has a bad valve or a broken piston ring or more and even a cracked head and gasket letting the water through,,,also the broken ring works like a oil pump as if not firing given you power then it works like a oil pump and pumps it into the cylinder that dosent work only pumping oil into the hot exhaust system while running.CAUSING SMOKE
And if a turbo then could be the turbo bearings worn and pushing oil into the engine and still doing the same as before.
Let me know how you get on. RON
Nov 17, 2009 | 2007 Mazda B Series
Estima starting problem
hi im rob r u looseing water white smoke indercates cracked head or blowen cylinder head gasket and the turbo wont provent it from starting turbos r just to give u more power
Apr 23, 2009 | 1993 Toyota Previa
Loss of power and acceleration on Mazda 6 Turbo diesel 2003
I'm assuming that that smoke was more previlant while going uphill because that's when the turbo would be really spolling up to max psi. I would guess that if you really got on the gas hard and got the turbo going even on a flat surface, that you would notice the smoke too. The loss of power and the white/grey smoke are tell tale signs that your turbo is bad or starting to fail. Good luck!
Dec 30, 2008 | 2003 Mazda Mazda6
Car Audio & Video Logo
98 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
