Question about Breville Kitchen Appliances - Others
How do i get the screws out of a breville toaster? I want to fix my TT4 toaster but can't get the screws off the bottom!
    Problem Solver:
  • 10 Answers
I took a 3/16" common (straight) screwdriver bit from one of my cheap universal driver bit sets, chucked it vertically in my shop vice, mounted a grinding disk in my Dremel tool, and ground a 1/16" wide by 1/16" deep slot in the center of the bit. It worked perfectly.
A hacksaw blade carefully placed could produce the same tool.
Posted on Dec 15, 2011
    President:
  • 2,992 Answers
You've probably discovered that the manufacturer used some kind of security screw. The heads have nonstandard slots and need special drivers. Many manufacturers do this to keep people like us (those who like to fix rather than toss something, that is!) from opening the item. They worry about being sued, I suppose.
There are many online sources for drivers, but some real oddballs are in use.
Here's a trick you can try if the head of the screw is thick enough. Grab the head across its diameter with diagonal cutters and squeeze. Unless the screw is hardened, the edges of the cutter will bite into the screw head. Continue squeezing and turn the cutters and you can usually break the screw free that way. After you get the screws out, pop into a local hardware store and get replacements of the same size and thread, but with a standard head.
Or just accept that not everything is fixable, toss the toaster and get a new one. Sometimes, once you finally manage to get something open, you find you wasted all your effort.
"Would you like some toast?" - Talkie Toaster
Posted on Feb 04, 2010
  • Douglas McCreadie Apr 03, 2012
    I took a small standard screwdriver, small enough to fit into the recessed screw hole, and then took a Dremel tool and cut down the blade to form a tool that fit the proprietary screw heads used by Breville. This worked perfectly for extracting the screws. Good Luck!
Toaster wont stay down
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
Jan 12, 2015 | Breville Vtt002 Polished Stainless Steel 4...
Toaster lever stuck in down position
I just fixed my Breville CT75XL Ikon 4-Slice toaster which was stuck in the on-down position. Wife said it heated up the whole kitchen and finally unplugged it. There are tamper proof screws as well as needle nose pliers needed to disassemble what appears to be a unit that is not intended to take apart or service. All I did was release the mechanism that holds and powers on the device then scrape the metal contacts with an emery board. Unit works but this buys me time to find a replacement. It won't be another 170 dollar disposable Breville made in China that's for sure. Only got 3 years 4 months use, family of 2, which is pathetic.
Aug 16, 2013 | Dualit Kitchen Appliances - Others
The Breville BOV650XL will not power on.
I had the same problem with my Breville B0V650XL. It worked fine at breakfast, then wouldn't turn on the next time I tried to use it. Judging by the comments on this site, this appears be a common problem with this and many other Breville products.
I fixed my toaster oven by replacing the thermal fuse assembly. This part costs $4.39 on ereplacementparts.com. It's a shame that an expensive toaster oven is rendered useless by the failure of such a cheap part.
Replacing the thermal fuse itself is very simple - you'll need a small wiring nut and a phillips screw driver. Unfortunately, getting to the part requires removing the oven cover and about 40 screws. A long, magentic scewdriver is essential for parts of this job. It took me about 1 hour to fix my oven - two minutes to replace the fuse and the rest of the time to remove and replace the oven cover.
Feb 25, 2012 | Breville BOV650XL 1800 Watts Toaster Oven...
I have a Breville toaster and the lever will not lock when toasting. I was able to remove the screws, but I am unsure how to remove the handle on the lever to allow the case to be removed.
1. Remove bottom screws;
2. Remove side handle;
3. Only pry up the casing from the black bottom base;
4. Turn the toaster back in up-right position;
5. Facing the lever end, (may be easier with a helper), lift the casing about 2-3 inches and unplug the wire on your left side then lift it up completely but be careful because another wire on the right side will remain attached;
6. You are now facing an electronic card and behind it lays the source of your problem. A small 3/4" x 1" white plastic. An electro-magnet. Some bread dust, not crumbs but real dust. You need to clean them all. probably easy with an air compressor or even a can of compressed air duster used for computer. The worse scenario is to unscrew what hold the electronic card in place and the 2 screw that hold the electric cord in place. Then you get a very good access the the source of the problem.
Even after 19 months, I did get a new toaster from our canadian Breville's distributor but after another 24 months, this time they offered me a 40% rebate to purchase a new one. No thanks, I decided to try to fix it or buy a different brand. We succeeded, my son and I. Good luck to you.
Oct 25, 2010 | Breville CT75XL 4-Slice Toaster
I HAVE A CUSTOMER WITH 8 OF THESE UNITS AND WOULD LIKE TO SEE WHERE I CAN GET PARTS FOR THEM
i need to know why the dryer makes a rubbing sound and how do i take the bottom
piece of the dryer to see if it is clogged.
May 28, 2009 | Breville BTA840XL 4-Slice Toaster
Removing bottom cover to access fuse etc - toaster not working
Hi.. the screws on mine are pozidrive (plus sign shaped slots).. what do yours look like?
What's your toaster problem?
Dec 02, 2008 | Breville CT20 Retro Classic 2-Slice...
Breville classique toaster
May 12, 2008 | Breville CT20 Retro Classic 2-Slice...
Kitchen Appliances - Others Logo
1,729 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
