Question about Casio Exilim EX-Z750 Digital Camera
The problem that recently occoured is that the camera says "the card is locked" then turning it on. also, you can preview pictures, but you can't edit them on the camera. i tried to make photos without SD, and ir worked, but however with the memory of this camera only 3 photos can be made. the SD card works fluently when putting it on PC.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position nearest the contacts unlocks them, the position farthest from the contacts locks them, protecting them from writes. If the switch is already in the correct position, try sliding it fully away from the contacts and then back toward them.
If that doesn't work, try a different card.
Posted on Feb 04, 2010
Testimonial: "tried to slide and it worked. thanks a lot :)"
Protected momery card
If you did not remove the memory card before, it could be there is a bad contact on the memory card or in the camera. It also could mean your card is full. (you should delete some pictures) First put the pictures on the computer or another memory, like external hard drive, or somewhere in the cloud.
If you recently had your memory card out, it could be you accidentally switched it to lock. See the picture how the switch on the SD card should be. The 64GB card is unlocked, the 32GB card is locked. Make sure your switch is up like on the picture.58575d9b-f54f-431e-b178-18861b326f77.jpg
Jan 26, 2014 | FUJIFILM FinePix JV200 / JV205 Digital...
Not working on preview
did you save the pictures into the card and not the cameras memory?
If you plug the card into your pc with a card reader you can have a look inside and also there are file recovery programs available if the card has gotten corrupt but the pictures where saved in it so it can be saved. but if no pictures are saved into the card then tehre is noting to recover,
Jul 07, 2008 | Canon PowerShot SD10 / IXUS I Digital...
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
My Leica Digilux 2, recently purchased and never used before, doesn't appear to be taking pictures. It reads all memory cards (residule photos previously taken) however when taking a snapshot, the display...
Does the menu in the camera work?
You may need to activate some Postview function in the menu. If the camera takes pictures, you should be able to view them in playback mode. There could also be a Preview mode, which requires pressing OK before storing pictures. Preview/Postview should cancel each other though...
Apr 13, 2010 | Leica Digilux 2 Digital Camera
When I power up my Sealife Reefmaster Mini without a memory card in it the preview screen has data on it like it normally does (except it says memory full). when I insert the SDHC memory card in it like I...
there could be something in the card port, you should also trydown loading any pictures on the internal memory & format it the (if you can) format the card with the camera
Jan 14, 2010 | SeaLife Reefmaster DC300 Digital Camera
A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
I recently bought the camera and was able to take 45 pictures without a memory card. I then put a memory card in from my phone and it allowed me to take pictures. However, once I took the card out and...
Be sure that the Lock switch on the memory card in your camera is set to unlock. If it is unlocked then try and see if you can reformat the card with the camera.
Jun 10, 2008 | Samsung Cameras
Preview Picture - Locked Up
Eventually, the camera's battery will die. I suggest removing the battery and then wait for 30 seconds and put it back in. This should solve the problem.
Feb 29, 2008 | Kodak EasyShare DX6490 Digital Camera
Memory card malfunction...
If the photos are important the first thing you want to do is get a memory card reader and use it to get the pictures off the card. A SD card reader can be found for about $5 bucks online and it will let you simply COPY and paste the pictures onto a folder on your computer. Make sure you COPY and not CUT because in case something goes wrong during the transfer you won't lose your precious photos.
It is possible that the camera driver is corrupted or deleted on your computer. Honestly it is not worth the hassle to deal with the camera drivers... it is much easier (and faster) to transfer the photos using a card reader.
Sep 08, 2007 | HP Photosmart M417 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
41 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
