Question about Daewoo Computers & Internet
When i power down to standby,and start it back up, it wont start back up again despite the fact that i press power to the monitor or shake the mouse
  • 66 Answers
Is there a "wake up" key on your keyboard? if yes,try using that?
Posted on Feb 04, 2010
"no signal" showing on tv screen
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
Cant leave laptop cause screen wont come back on
It would seem that for some reason, the display would not activate again after going to standby. This would involve checking the inverter circuitry that powers the CCF lamps (backlight).
A possible temporary workaround is to disable/deactivate the "Turn off monitor" feature in your laptop's Power Scheme.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Acer TravelMate 2300 Notebook
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
Can't wake the computer
Probably there is no connection between your keyboard and mouse to the CPU. Check for proper connection of your keyboard and mouse. If the connection is good, probably there is the problem with the cord that is connected with your mouse or keyboard.
Turn off first your PC before making any connections.
After you confirmed that there is no problem with the connection, probably the problem is at your mouse or the keyboard itself.
Apr 21, 2009 | E-Machines eMachines Desktop PC
When ever i turn my laptop on..it boots properly..then ill be typing and it will shut off..or go on standby not sure then i will push the power button...but it doesnt rootboot ...and starts back up where i...
Try this.
Right click on desktop.
Mouse down to properties, & left click.
Left click on screen saver.
Mouse down to Power In monitor power, & left click.
Check your power settings & hibernation settings.
Also some computers are setup to hibernate if mouse is placed in certain parts of the screen (top right or left, Bottom left or right.
Hope it helps.
Mar 11, 2009 | Dell Inspiron 1525 Notebook
Computer dead despite working power supply (power and charger LED are off)
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Oct 31, 2008 | Toshiba Satellite A215-S7422 Notebook
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
COPIER KIOCH FT5840
Hello Woolfmoon.Despite the fact I have long since thrown away all my documentation on this machine since is an analog machine and is quite old (but a good machine),and despite the fact that I cannot tell you the entire specifics of that particuliar erroe code because I dont have the manual,and despite the fact that I am graded on how well I help you out and "FIXYA", I will give a decent accessment. SC 544 has to do with the fuser. A temperature error ocurred (under/over.....time frame). Because of the intense and potentially dangerous heat that is intentionally generated @ the fuser there are many aspects of the fuser's characteristics that are monitored. Even general power conditions in the copier's enviroment can cause the safety monitors related to the fuser to generate an error as the safeguards are very sensitive. You can reset the code in the event it was generated erroneously or the problem has been resolved. Your copier has to believe that a "technician" fixed the problem so I will tell you how to do that. Press "clear/modes(yellow button) , then press the numbers "1 0 7" and then press the round orange stop button and hold it down until you see the the display change and begin to flash. For example the display area that would normally show you the number of copies you had requested should be flashing if you had successfully entered "service mode". So to be nore clear.......use your index finger as your brain and press CLEAR/MODES then 1 then 0 then 7 then hold down orange start button foe several seconds till the display changes. THEN....... :-)........turn off the main power (if you are in doubt unplug that baby). This will tell the copier to chill out and try to reboot again as if nothing was ever wrong. But if the problem still exists the copier will shut down again and give an error code. If that occurs you have a genuine and potentially dangerous problem in the fuser. I hope I helped a little, and wish to have helped you alot. Take care. Let "Fixya" know if I was of any help at all please.............SPINAL
Apr 08, 2008 | Office Equipment & Supplies
Likom HD17A blacks out
Just check that your monitor is not set to power down(Control Panel> Power Options) and check that the 'Turn Monitor Off' Power Scheme is set to never and turn off any screensaver to see if it still goes off.
Oct 24, 2006 | Likom HD15A 15" LCD Monitor
Computers & Internet Logo
112 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
