Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Where do I get a power cable from?
Where do I get a power cable from. My cable has snapped right at the plug, but i cant seem to find a site where you can replace the cable.
    Problem Solver:
  • 18 Answers
What exactly rbroke off? if it is just the plug that goes into the hard drive case, then take the old "wall wart" (ac box-plug) to your local radio shack, with the broken off jack, and ask if they will solder a replacement fon for you, should be only a couple of bucks if not free (for the soldering, the jack may cost you 3 bucks), take a look at the rear of the hard drive case and write down the plug polarity (if its positive or negitive center pin)
Posted on Feb 08, 2010
    Sniper:
  • 91 Answers
For any type of buying..try amazon.com
Posted on Feb 04, 2010
Indesit wib101
THE COPPER CORE OF THE MAINS FLEX/CABLE IS LIKELY SNAPPED INSIDE THE INSULATION (USUALLY NEXT TO THE PLUG (IF YOU'RE LUCKY) OR NEXT TO THE MACHINE AS THESE ARE THE 2 BITS THAT MOVE/FLEX MOST). TEST THE CABLE (ALL 3 EARTH LIVE & NEUTRAL) WITH A CIRCUIT TESTER. IF BROKEN BEST TO REPLACE THE WHOLE CABLE BUT IF YOU CAN IDENTIFY THE BREAK YOU CAN CUT OFF A SECTION AND REFIT THE PLUG.
Dec 09, 2013 | Washing Machines
The cord from the power supply isn't able to go into the proper place..there seem to be restrictions
Easy fix, look inside the plug on the console.
You will notice a small semi square tab right
in the midel of that plug . Take a screwdriver
and flex that square tab over and it will
break off and then you will be able to insert
the power supply plug , this little tab is simpley
to prevent the use of certain power supplys
but I snap them off all the time and plug in
my generic 175 watt power supply for testing
and never had a problem.
if you need more info ask
Rob
Dec 24, 2009 | Microsoft Xbox 360 Console
My Garmin nuvi 255W will not go off of the garmin screen....any suggestions
You can try plugging it into a computer via usb cable and see if that snaps it out of it other wise try doing a hard reset, you will loose all data but its the only option you seem to have. Hold the bottom right corner of the touch screen and power the unit on. wait until you see the confirm delete and select yes.
Aug 14, 2009 | Garmin nuvi 255W GPS Receiver
I want to replace the internal power source on my Compaq Presario. Aside from getting the right replacement part with the correct style plug, are there any traps for this rookie installer?
aside from getting the right part you don't have anything to worry about.
not sure which is the right part?
go here: http://h20141.www2.hp.com/hpparts/default.asp?cc=US&lang=EN
and type in your model number
then power supply
Jun 25, 2009 | HP Compaq Presario SR2010NX PC Desktop
Optiflex GX260 does not power up
any beep codes?? if there isnt any beep codes your power suply probly isnt producing enough power to boot the system you can check for a burnt or hot smell coming from the power supply if you smell burnt pop corn then you need to replace the power supply they make a power supply tester but if your only needing it once not worth 20 dollars to buy it if the power supply is replaced and it still isnt working the mother board is toast
Jun 05, 2009 | Dell OptiPlex GX260 PC Desktop
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Electric window
You to install the motor to new power window assembly ,as the cable is snapped just the assembly and old motor to it it will work...
Good luck..
Aug 18, 2008 | 1997 Volkswagen Golf
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
Magellan Roadmate 700
I had a Roadmate 700 with the same problem as yours, and the solution was simple: the hard drive inside had come loose!
All I did was open up the unit (4 screws on the back and a small snap-together clip on the end), and plugged the hard drive back into the cable. The cable has 2 black posts that fit into the hard drive, so you can't misalign the pins. On mine, the hard drive label was facing UP.
Once the hard drive was plugged in, I powered up, and could hear the hard drive spin up (which I hadn't heard before). The unit booted from the "Magellan" screen right into the menu almost immediately!
Hope this helps someone!!
May 23, 2008 | Magellan RoadMate 700 GPS Receiver
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
264 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
