Question about HP Computers & Internet
Cpu and chssis fans not working pls help
Cpu and chssis fans not working , tne machin making beeb and shutdown
pls help
    Problem Solver:
  • 11 Answers
Check if your pci cards and memory sticks are all the way in.
Also check (if you have a video card) if its sitting correctly.
What i would do is remove and reinstall all your pci cards one at a time.
Posted on Feb 04, 2010
I have a constant beeb beeb ----beeb beeb---beeb beeb from my speakers or headphones but not from the computer tower when the speakers or headphones are removed. Is this a audio problem with PC or a virus?
Hi there
A couple of points.
Many system boxes no longer have built in speakers, and if they do they are very simple and simply used for POST errors and other alarms eg CPU fan failed, overheating etc. If there is a pattern to the beeps, you need to check against your BIOS codes to ensure nothing serious is happening.
If your system is working completely normally otherwise, then I would suspect an audio problem, which might be resolved by removing and re-installing the audio driver from the disk supplied.
Cheers
Nov 10, 2014 | Computers & Internet
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
Dell PE 1800 showed one SCSI 73G non critical state on a RAID 5 array of 3 disks. Shutdown the server, removed the SCSI disk and booted, server booted but continous beep sound, trying to rebuild the array...
Hi, try to renew the drivers and firmware from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=PWE_1800&os=WNET&osl=en&catid=&impid=
Continuous beep related to ram ,try to remove ram and insert it, and if u still get beep change your ram.
Continious beeb sound is ram or cpu failure. Is the cpu fan spinning ??
If not the cpu is over heating.
Try to remove the ram modules and clean the contact points
with a piece of paper. Be very carefull when you do that !!!!!
And blow the dust out of your server, with a high pressure can.
Hope this was helpfull.
Mar 28, 2011 | Dell PowerEdge 1800 Server
Help w/ my cpu it shut down automatically pls help
Check your power settings in the control panel, check that the keyboard has no buttons that can cause shutdown.
Check that your fans are working, and then check the event logs to see what has been happening...
Oct 11, 2010 | Dell OptiPlex GX280 PC Desktop
Machine is running but after a few minute there is no display screen shows black in mercury motherboard PVM7 pro model. I install 2pcs new ram (1GBX2) but machine shows each slot 512mb instead of 1gb...
Any beeping if there is
CPU cooling fans seized of about to seize?
This should happen in 30 second for a thermo shutdown.
Reseat the cpu make sure there is thermo white compound between the heat sink and Top of the CPU
make sure there is proper flat seatin of the heat sink and CPU make sure the fan is working.
It can be ur video or monitor,
Aug 26, 2010 | Computers & Internet
I have a custom built computer w/ xp pro. my computer shuts its self off. why? sometimes it will do it 4-5 x a day, then there are days it won't do it at all. any suggestions?
Automatic shutdown can be due to mostly over-heating of the CPU or CPU fan not working properly. Blow the CPU areas plus the CPU fan with an Air-blower and check if the CPU fan is working properly or not. If the CPU fan is malfunctioning then replace it. Your system will work fine.
Make sure your system is free from virus and worms as it too can be the cause of  system shutdown (but this cases are very very rare).
That's it.
Mar 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Cpu fan can not detect when boot at hp dx 2300
check the fan and be sure it is plugged into the motherboard
Aug 14, 2009 | HP Compaq dx2400 PC Desktop
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Monitor keeps shutting off
it is a "CPU THERMAL SHUTDOWN"
Make sure the CPU fan is working. If there are any other fans on the motherboard, make sure they are working.
Make sure the case fan(s) are working and that there is no obstruction to the airflow into and out of the case.
Your CPU fan may be broken and you will need to buy another one.
Was this solution helpful? Show your Appreciation by rating it:
Feb 10, 2008 | Gateway FPD2275W LCD Monitor
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Computers & Internet Logo
37 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
