Question about Bosch Axxis WFL 2060 Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
If I get a spare gasket , How do I remove old one and refit the new one??
    Sergeant:
  • 228 Answers
You will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Posted on Feb 17, 2010
  • Bosch Master
  • 744 Answers
Bosch Axxis WFL 2060 with front dor seal has a tear in at at the bottom.
This video will show you how to change a
door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
My MF135 Tractor has developed a leak round the bottom pulley. New gasket fitted round the timing gear but leak persists round crankshaft gear/pulley. How can I fix this?
Replace oil seal, check if pulley has grooves worn by the old seal. If it has resleeve with a resleeve kit from auto spares shop. Refit new oil seal & resleeved pulley.
Jul 08, 2017 | Cars & Trucks
Leaking filter housing
If the filter houising is bolted to the engine undo the mounting bolts and clean all old gasket from both faces. Get a new gasket and I use loctite blue as a sealent on clean dry surfaces (use VARY sparingly as excess can get into engine parts) Refit filter ensuring the correct tensioning procedure is followed Tip the old filter seal has to be removed as sometimes they stick to the housing unknowingly causing sealing problems with the new filter
Jan 12, 2013 | 2001 Chevrolet Astro
Fitting new door seal ,how to remove old seal and fit new seal?
Follow these steps to replace your door seal:
For all Free appliance repair videos visit ourVIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a springsystem holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in ourtutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Mar 31, 2010 | Hotpoint Aquarius WD640 Front Load...
Seal on door leaking---where do we get a new seal?
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Jan 03, 2010 | LG WD-1080FD Front Load Washer
Repacing the door seal on my oko lavamat washing machine
this could be out of the door tension clip you might see it in this video
Sep 04, 2009 | AEG Lavamat 88840 Front Load Washer
LG Washer leak, small tear in door seal
Jul 04, 2009 | LG WD-1080FD Front Load Washer
Zanussi wjd1667w door seal dislodged
For all Free appliance repair videos visit our VIDEO TUTORIALS
May 26, 2009 | Zanussi WJD1667W Front Load Washer / Dryer
Zanussi ZJ1217 door seal
Sep 03, 2007 | Zanussi ZJ1217 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
187 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
