Question about Electrolux Washing Machines
Error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Posted on Feb 15, 2010
  • 42 Answers
Hi Sue
Quite often the manual definition of error code can be quite vague. I would suspect a couple of possibilities. You could have a kink in your outlet pipe, your outlet pump could be faulty or you have a blocked internal or external filter.
Regards,
Posted on Feb 16, 2010
The problem is the door open/lock mechanism. if you can remove it you just need to clean the contacts inside with emery paper/sand paper and re-assemble.
Posted on May 22, 2010
Model EDI97170W code error E20 appear on the LCD panel.. is means for
An Electrolux?
The E20 fault code means there is a blockage in the drainage system of the machine.
Check the drain hose, the laundry sink tub and also the pump filter at the bottom right hand side of the washing machine on the front of the cabinet. Pry the door open, undo the filter bung and clean out the pump housing ok,
One of these is blocked and it is restricting the flow of water when the machine should be fully drained before spinning.
Dec 04, 2016 | Washing Machines
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Electrolux washer ewf1084 error code e20
Hello - Error code "E20" typically indicates that the water is not draining properly or not pumping out fast enough. Is the washer making a humming noise? If so, either the drain hose may be kinked or the household drain is clogged. Otherwise the unit can be experiencing more serious issues, like a faulty pump or Main Control Board. If I was in your position, I will personally consult a certified technician for a proper diagnosis and to move forward accurately.
Feb 19, 2013 | Washing Machines
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Wat is code for e20 on a ewf 1080
E20 error code measn blocked filter. Removing the blocked filter you have to remove the water from inside by using the small flexible tube which located next to the filter at the right bottom of the machine. Then the only think it still remains was to unscrew and clear the filter.
Hope helps.
Apr 22, 2011 | Electrolux Washing Machines
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Apr 20, 2010 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Aug 12, 2008 | Washing Machines
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
7,180 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
