Question about Electric Bicycle Motor, Bike,electric Bicycles ,kits
Sakura S305 electric bike, no speed control
When out riding my bike {a Sakura S305}The motorstarted to speed up, even with throttle fully off,when i braked everything went dead.i have found a fuse blown in battery pack,when i replaced it all electrics came alive,but motor still goes full revs with no control with throttle control.please helpbill
The Controller is goosed!! It\'s had water ingress & messed up the PCB. This is the same as some of these electric scooter\'s I had to fix years ago. One of them mysteriously came to life in 1 owner\'s kitchen in the middle of the night & went mental! It wasn\'t switched on or nothing & the owner just threw it into the garden to let it "do it\'s thing!". Replaced the controller & right as rain! The same can happen where it just goes to full throttle without revving/riding it. The controller was at fault on these occasions too! Hope this helps?
Ian @ On Yer\' Bike! M\'bro Bike Shops Middlesbrough Bike Repairs North East On Yer Bike...
Posted on Mar 18, 2014
  • 53 Answers
I'm not familiar with that make/model, but if it has a brushed motor then it is likely that you have a faulty controller module. Most brushed motors have just 2 wires running to them from the controller.
Posted on Oct 16, 2013
Sekura electric bike I have power to lights and indicators but the bike wont drive.?
I am not familiar with Sakura, but if it is fitted with e-brakes then you could try disconnecting one then the other to see if it now works. If it does then your ebrake is faulty & you need to replace the brake sensor in the e-brake or the complete e-brake lever.
May 11, 2014 | Electric Bicycle Motor, Bike,electric...
Sakura s305
That is an unusual value. You could try a 25 amp fuse instead as this is a more common value. RS Components or other electronics parts sellers should have them.
Jul 22, 2013 | Electric Bicycle Motor, Bike,electric...
Sakura electric bike .Red and blue cable broken off right hand brake lever. Can I open it and re-solder?
I once spent 2 years and many attempts to solder a VW Bus throttle cable, finally had to get 2 cable clamps and a short piece of wire, fixed it in about 6 min and it never failed again.
Feb 02, 2013 | Cycling
I have a sakura s200 electric bike can i make it any faster ?
Change out the gears with a higher ratio that turns the wheels faster for the same motor RPM. Another method is find a motor that has a higher rpm capability.
Aug 23, 2012 | Electric Bicycle Motor, Bike,electric...
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
2009 ultra classic's electronic throttle. turning
Hi Tealpig, call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day.
Mar 01, 2012 | 2005 Harley Davidson FXDLI Dyna Glide Low...
Basically I'm losing a lot of corner speed, when turning into corners. I shut the throttle off too early and it feels like I'm carrying the bike round the corner. If adjust the throttle mid bend,...
You need to accelerate very gently while you go round the corner. This sounds wrong but even if you hold the throttle in the same position, physics dictates that as you go round the corner you do actually accelerate as you go round a corner at a constant speed (velocity/direction/speed - look it up if your interested!).
So on the approach to any corner, you need to: -
1 Position yourself and the bike for the approaching bend, toward the right hand side of your lane for left hand bends and vice versa.
2 Adjust your speed to one you can quite happily ride around your bend (Slow down by easing off the throttle or appling the brakes)
3 Once at the right speed, (off the brakes) select the right gear for the speed your doing.
4 GENTLY apply some throttle to stop the bike slowing down anymore.
5 Tip the bike into the corner by gently pushing on the left bar for left handers or vice versa keeping the throttle still so that you hold your speed through the corner.
6 As the bend opens up (becomes a straight) gently apply more throttle as you release the pressure on the bar and stop turning.
If you want to keep improving your riding skills, sign up to a advanced riding course. They are for people who enjoy riding and want to be safer and consequently faster.
Good luck with your riding and enjoy!
Jul 28, 2011 | Suzuki GSX 1300 R Hayabusa Motorcycles
Electric bike cuts out while riding
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
Jan 14, 2009 | Electric Bicycle Motor, Bike,electric...
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
1,060 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
