Question about Panasonic Pansonic SH-PD10 Universal Dock Docking Station for iPod (037988255443)
I have a panasonic surround sound system with an Ipod dock. I have had no problem using this dock with my Iphone, provided I enable airplane mode. I have been able to play music and watch videos on my iphone throughthis dock. However I have recently encountered a problem. When I put the iphone onto the dock the surround sound system confirms that it is connected but when I play a video on the iphone only the sound goes through the surround sound system. The picture plays on the iphone and not through the TV. this has only just become a problem. I have tried different Iphones and I have checked all the connections and system settings but kep getting the same problem. Is it a physical problem with the dock itself? Any help would be much appreciated.
4 Suggested Answers
SOURCE: cANNOT WATCH iPOD mUSIC vIDEO on Panasonic SC-PT865
Maybe because is only read audio, like Photos and mp3 audio only, expecially if read format llike "High Mat" to read photos and music, try to go to instructions manual and see the format what your dvd read.
Posted on Jan 15, 2009
jomabug76
  • 1148 Answers
SOURCE: No sound from TV to home theatre system
hdmi does sound to,,,try if the reciever has hdmi,,unhook the optical cable and try it by itself,,and vise versa
Posted on May 17, 2009
SOURCE: panasonic sapt560 can i connect my iphone?
yes, the i phone works as well
Posted on Jan 27, 2012
How can I turn off the busy signal on my phone?
Check your iPhone settings
  1. Turn airplane mode on and off. Tap Settings > Enable Airplane Mode, wait five seconds, then turn airplane mode off.
  2. Check your Do Not Disturb settings. Tap Settings > Do Not Disturb.
  3. Check for any blocked phone numbers. Tap Settings > Phone > Blocked.
  4. See if Call Forwarding is turned on. Tap Settings > Phone > Call Forwarding.
Update your software
  1. Check for a carrier settings update.
  2. Check for an iOS software update. Some updates might require a Wi-Fi connection.
Remove and reinsert your SIM card If your iPhone has a SIM card, remove the SIM card, then reinsert it. Update your Preferred Roaming List (PRL) The PRL determines the cellular towers that your iPhone uses for cell service and selects those with the best signal strength.
  • If you're on the Verizon network, dial *228 and select option 2.
  • If you're on the Sprint network, dial ##873283#.
Contact your carrier When you contact your carrier, check the following:
  • Your account is set up to use your iPhone.
  • There aren't any localized service outages.
  • Your account doesn't have a billing-related block.
  • Your calls don't have errors on the carrier system.
Check your network settings
  1. Reset your network settings. Tap Settings > General > Reset > Reset Network Settings. This will erase all current saved settings, including Wi-Fi passwords, preferred networks, and VPN settings.
  2. Try to make or receive calls in another location.
  3. Switch to a different network band. Tap Settings > Cellular and turn off Enable LTE, 4G, or 3G (this option will depend on your carrier and device model).
Still can't make or receive calls? If you still can't make or receive calls, restore your iPhone as new.If restoring doesn't fix the issue, contact Apple Support or take your iPhone to an Apple Retail Store or Authorized Service Provider.
Mar 14, 2016 | Panasonic Lands Phones
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Dec 26, 2012 | Panasonic SCHC57 SC-HC57 SC HC57 Compact...
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
Bose sounddock not giving any sound. Ipod working fine through earplugs. Unhooked soundock for travel, now no sound. Tried all the resets, etc. Also, new battery in remote and it doesn't respond either????
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Jun 07, 2010 | Bose SoundDock digital music system...
Will the apple ipod nano 5th gen. work with this system. Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers
  • Compatibility: iPod mini; iPod nano 1G, 2G, 3G, 4G; iPod classic 4G, 5G, 5.5G, 6G; iPod touch 1G, 2G; iPhone, iPhone 3G, iPhone 3Gs
  • Wireless audio system includes iPod Dock/Transmitter and two wireless speaker systems with LCD display and alarm clock function
  • AM/FM tuner provides alternative to iPod content; multi-zone function means iPod can play in one room while radio plays in another
  • Expandable system is easy to set up, and is compatible with up to ten speakers with the compatible audio receiver
  • Connect to your home AV system with composite audio and video cables for enjoying iPod content
  • May 07, 2010 | Apple iPod nano 5th Generation
    Compatibility issues iPhone 3G - JBL On Stage IIIp
    hi there, believe it or not, apple has put a authentication chip into newer devices. It won't allow you to play music or display video on devices that are old. Apple wants you to go out and buy new accessories for the new stuff to make more money. My suggestion is to sell it on eBay and use the money to get a newer compatible dock with your iPhone.
    Feb 17, 2010 | On Stage Stands JBL On Stage IIIP Portable...
    My ipod wont play in the unversal dock
    What Ipod? Universal docks aren't all that universal.
    If its an Iphone put it in airplane mode.
    Unplug the unit, remote the Ipod, plug it back it, re-dock Ipod. If your Ipod is shorting the combus that will correct the issue.
    Cheers,
    Kevin
    Jan 25, 2010 | iSymphony M1 Shelf System
    After I dock Iphone 3G in JBL Stage II an error message opens
    Have you tried not setting it to aeroplane mode ? If you cant put up with the error or if their are bigger issues, sad to say you would have to update you jbl stage to a model that supports your version of firmware or phone model
    Jul 29, 2009 | JBL On Stage Speaker Dock for Apple iPod...
    Home theater compatibility
    You should be able to select "no" when it asks Do you wish to use airplane mode and the phone should still work.
    Not all of the features of the home theater system will probably work but you won't know for sure until you try it
    Nov 17, 2007 | Apple iPhone Smartphone
    Panasonic Pansonic SH-PD10 Universal Dock Docking Station for iPod (037988255443) Logo
    75 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
