Question about Dell Latitude D620 Notebook
Dell Latitude D620 isn't getting power to the mainboard.
Hello. I'm trying to fix my dads Dell Latitude D620 laptop. It was working fine then he said it wasn't doing anything when he hooked up the ac adapter.
I checked the ac adapter, I also checked the battery and ac jack.
All of the above are in perfect condition, I even OHM tested the cord and ac jack.
He said it was working up till the battery died.
From what I can see this is a somewhat common problem, I tried the charger from my brothers Dell laptop and it does nothing, no power light or charge light.
From what I've found, people want over $200 to repair the mainboard. I found one thats used for under $130 and I'm going to go that route if I can't figure this out.
Thanks in advance for any help.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 29 Answers
Diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Posted on Apr 23, 2010
Dell D620 laptop screen won't come on after disconnect from docking station
please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
Mar 05, 2013 | Dell Latitude D600 Notebook
The screen of my Dell Latitude D620 laptop won't
there should be a strip of plastic above the keyboard that has power button and it you should be able to take it off to get to the hinges.
Aug 02, 2012 | Computers & Internet
My Dell Latitude D620 laptop will not boot up unless I hold the power button down. The computer will run fine if I keep holding the power button down. It will also keep running if I hold down any key. As...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 04, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
My dell latitude d620 will not turn on? I took out the power cord and battery and put them back still nothing.
It might be the mother board is bad if it will not boot are there any lights when you try if not then I would replace the mother board you can find one on ebay then you need to put it in If you go to this link it will give you step by step
http://ahwee.com/how-to-disassemble-laptop-dell-latitude-d620
Aug 25, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Dell Latitude D620 - push the power button and the power light stays on for about 5 sec, then black. No disk activity or any other lights during this time. It is not HD, as I can put this HD in another...
1.Remove the battery and insert the A/C main adaptor,then ON the Laptop.
2.Remove and Insert the RAM again properly(Cheak with another Good conditioned RAM)
3.Remove the CMOS battery and then repace it again.
4.Remove all drives like hard disc,dvd drive and etc.then ON the Laptop.
All the Best....
Jun 21, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Is dell latitude D620 laptop have a web cam.
dell latitude D620 do not have webcam
if you want to have a latitude laptop which com with builtin webcam then buy Latitude E series.
Jun 08, 2010 | Dell Latitude D600 Notebook
Dell Latitude D620, Black Screen/Power On
It is the backlight! That laptop uses a fluorescent lamp. It is bad.
If you look carefully at the screen, you will see the Windows desktop (or whatebver you are running). It just needs to be lit up.... from the back. Tel them to replace the LCd screen or replace the lamp.
Hope this helps!
Sep 07, 2009 | Dell Latitude D620 Notebook
Laptop Will Not Turn On
first remove batterry from it for 5 minutes ckean its from, dust.
May 08, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell Latitude D620 Gray Screen
I don't know about that particular laptop but it sounds like a loose connection between mainboard and screen plus a bad inverter (regulates and supplies voltage to the actual screen from the main power source). Laptops typically have the inverter hidden somewhere in the frame that surrounds the actual lcd screen. Sometimes this regulator is part of a small circuit board, sometimes it is not (I suppose it might be part of the actual lcd in some cases, but i've never seen that). I would investigate things further in that direction and just hope your lcd itself isnt bad.
Jan 22, 2009 | Dell Latitude D620 Notebook
Dell Latitude D620 Notebook Logo
1,045 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
