Question about Saeco Odea Giro Espresso Maker - Black/Silver
Saeco Talea ring main touch button is not working You can't get into the submenus or make coffe.All other buttons are working.
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
SOURCE: HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Posted on Apr 11, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Posted on Aug 28, 2009
  • 20 Answers
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
Posted on Dec 23, 2009
  • 81 Answers
SOURCE: Error Code 4 on Saeco Talea Ring
error code 1 means the grinder is not working, either the motor is bad or there is no power supply to the motor.Have to take it back to the Seaco service center.
Posted on Mar 06, 2010
My saeco talea touch wont steam out of the wand, it makes the noise like it is steaming but the steam is coming out of the bean hopper and the grind tray area
Your delivery pipe has been disturbed at some point and has dislodged or blown out the O-ring seal, or maybe careless assembly of said pipe seal, if under warranty, take it back.
Oct 19, 2014 | Saeco Hot Buy Talea Touch Plus Automatic...
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
Try this url…
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
The selction ring on the Talea Ring Plus doesn't work anymore, does anyone have a clue?
I had the same problem, after dismantling the machine I found that the touch detector is glued to the back of the plastic front panel and had become detached, so that it was too far from the operator's finger to work. Reattached with fresh glue, checked connection to main board, works perfectly now.
Dec 26, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Open Questions:
See all Saeco Odea Giro Espresso Maker - Black/Silver Questions
Saeco Odea Giro Espresso Maker - Black/Silver Logo
149 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
