Question about Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator
Refrigerator freezes food regardless of dial setting. Control board?
  • 2 more comments
  • lance154 Feb 04, 2010
    I apologize for the incomplete information. The fridge is a Kenmore Model Number 253.52649301. All the fresh food freezes. Thank you.
    Thank you. Can you supply a part number? I have fished all around for parts I suspected. But it is difficult to identify which part I need. Thanks
  • lance154 Feb 05, 2010
    Thank you for fast response with comprehensive answer. Your service is genuinely appreciated! Lance
  • Ricky Harrelson
    Ricky Harrelson May 11, 2010
    Model number?
  • 619 Answers
Thank you. The part number you need is 240383703 at $146.18 thru Sears and is the control for the refrigerator not the freezer. The refrigerator control operates the opening and closing of the damper door which lets air pass from the freezer to the fresh food. The control is keeping the door open longer than it should. Hope this helps. Worth the repair and has been one of the most common problems with this model.
Posted on Feb 05, 2010
Testimonial: "Fast response. Thorough, easy to understand explanation. Comprehensive solution. This service and the expert "Iwillfixforyou" are the best. Thanks!"
  • 52 Answers
Sounds like the internal thermostat is broken, seems it is stuck on the lowest setting.
Posted on Feb 04, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
I have a FF82 model and it is starting to freeze food. there is some frozen water in the bottom. The temp control dial doesnt move. What shoudl I do to fix this.
Temp dial shouldn't have a setting that would freeze your refrigerator side products anyway. Make sure damper to fridge isn't stuck or frozen which cuts off air from freezer to fridge when temp is achieved. If all working properly for sure. Sounds like bad temp control.
Oct 25, 2016 | Refrigerators
Food freezing
Hi Susan,
I had the same problem with food freezing on the bottom of the compartment, especially the veggies. I had set the thermostat to 34 for cold beer but I guess the thermostat is off a bit. I put a thermometer on the bottom shelf to make sure that I had control of the temp and set my thermostat until it was 36 inside. The thermostat on the front reads 40. I guess that 38 might be the magic number for you.
Jun 18, 2014 | Whirlpool GI5FSAXVY Stainless Steel ...
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
Food is frezzing up in refrigerator
Normally if the dial control is in the refrigerator section and is marked A,B,C,D then A will be the warmest setting. If the dial is marked 1,2,3,4 then 1 is the warmest setting. Hope I was of help to you!!
Nov 28, 2009 | Refrigerators
Food in my refrigerator freezes I have a top freezer maytag
There are 2 things to check - Your cold control dial - to rule out a thermostat problem lower it to 1 gradually and slowly until you hear a click and it shuts off - If it does not shut off, and only shuts off if you set it to the OFF position, then you have a thermostat problem and your compressor is continually running, freezing things in your refrigerator. If lowering your dial you hear a click and compressor shuts off, then the solution is to lower your dial, you have it set too cold - There is a thermostat in your refrigerator that should shut things off when it is cool enough it's either not working properly or your dial is set too cold.
Sep 05, 2009 | Refrigerators
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Kenmore 52642 / 52644 / 52649 Side by Side Refrigerator Logo
216 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
