Question about Refrigerators
Whirlpool S21S4D Ice maker stopped working Now fridge stopped working Frezer OK Defrosted ice on condenser and fridge working for time being! Do you think its the mother board?
  • 619 Answers
You have a defrost problem going on. Either the defrost timer, the defrost t-stat or the defrost heater. Remove the back freezer wall and you will see the evaporator coils. This is where the heater and t-stat are located. One of these is more than likely the problem.
Posted on Feb 04, 2010
Testimonial: "We have just looked at the recommendation and it looks like the heater is not working properly! Will source the part tomorrow. Well done Fix Ya"
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
Whirlpool fridge/freezer ARC 7050
see if you can remove panel inside freezer to see if its full of ice all over condenser .Even if you already defrosted for 1 day..If its full of ice ..Then the DEFROSTER COIL is not working and not melting the ice on condenser and then stoping the cycle therefore compressor will stop running..Also there should be a a couple of thermal switches on the condenser(two wires) if this is bad then there is no cycle..goodluck
Dec 06, 2007 | Refrigerators
My s21s4d fridge ice maker doesnt work, everything else is ok. the motor on the ice m/c doesnt seem to reset itself. how do i fix it.
Hi and welcome to FixYa, I am Kelly.
This appears to be a Whirlpool side by side unit. Commercial Code 858618353010 / Model S21S4D. If I got the brand incorrect please respond with your brand name.
I do not know your geographic location. I am assuming you are outside of the US.
There are a couple of troubleshooting links I will post here. Keep in mind that they are for US units but the only difference will be the operating voltage:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34 This is for the BASIC ice maker without optics.
And Job Aid R-92 (With optics)
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note there are 2 different optics for these. Pre and post 2002. You will have to determine which one you have. The troubleshooting steps require that you TAPE the door / light switch in the depressed position. Ensure you read all of the set up steps.
Often ice makers stop cycling because the ice maker thermostat never reaches 14 - 16 Deg. F due to a problem with automatic defrosting. Ice builds up on the evaporator coils and air-flow in the freezer gets restricted. It will still freeze but won't make ice until the ice build up is excessive.
If you think you may have an automatic defrosting problem do a MANUAL defrost with an external fan by turning the unit off, removing the freezer contents and directing an external fan into the freezer compartment for just over 2 hours. (water mess so be ready)
While the fan is melting the ice in the freezer compartment... open the lower rear of the unit by removing the fiberboard cover and cleaning the condenser coils, condenser fan, the drip pan and the ver end of the compartment drain tube that terminates in the drip pan. Reinstall rear cover when complete.
After the 2 hours clean up the mess and return the unit to normal service. The unit should start making ice within 8 hours. It will operate normally for 2 days and then if the automatic defrost problem exists... ICEMAKER and freezer performance will degrade after 2 - 3 days.
Hopefully you have enough information now to troubleshoot your icemaker issue.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | Refrigerators
The automatic ice dispenser is not working. How can I tell if it is the motor or the switch not working?
On my Whirlpool, the water splashes on the rotating parts and sometimes freezes the maker stopping it. Pull the plug on the fridge, use the hose on a vacuum machine plugged into the exhaust to get warm air to the ice maker or use a hair dryer to warm up the ice maker. After you are sure it is defrosted, plug the frige back in and listen for sounds of the ice maker turning or observe every couple minutes to see if the rotating parts are turning
Dec 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
