Question about Refrigerators
Red warning light on - Servis Fidge Freezer
The red warning light is on and my food has defrosted but the fan is still working.
  • 619 Answers
Check the overload relays at the compressor. Make sure comp. is running. If not replace the overload relays. Hope this helps.
Posted on Feb 04, 2010
The red warning light is flashing after freezer being moved
This will happen until the temperature gets down to an acceptable temperature.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 20, 2012 | Freezers
Ihave recently moved my fridge freezer ,and the red alert light has come on,could you tell me what is wrong,thanks
It comes on when there has been a power interuption to warn of a possible thaw of food or that the inside temp was high, it will correct itself within 24 hours or you can push the reset button beside the light to cancel.Please let me know if this works
Jan 19, 2011 | Hotpoint FFS70 Bottom Freezer Refrigerator
Servis fridage freezer red triangle exclamation light flashing. please advise.
i have a servis fridge/freezer m7065 3x/w1.
the fridge light constanly flashes and partly defrosts,then it becomes working again and vice versa.?
Oct 02, 2010 | Refrigerators
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Frige freezer
if you have frost in the freezer it either has an air leak on the gasket or the defrost system has failed and you need to call an honest appliance repair person,don't call sears$$$$$$$$$,check all around the gasket first,mike
Sep 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
Frige freezer
possibly due to not defrosting. take off rear panel in freezer and check if there is ice build-up on the evaporator. if so, melt off carefully with a hair dryer and appliance will then work. get back to me with what you find if you wish
Jul 13, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Freezer just stopped working
Several problems can cause this. It may be "stuck" in the defrost cycle, the compressor start device could have failed, the temp control system could have failed, evap fan could be bad and not circulating cold air, or worst case is the sealed system has leaked all the refrigerant out. Post again with more info like: Is the compressor running? Are there any fans running? Does the temp control turn the compressor off and on? It never hurts to unplug the unit for a few minutes and then plug it back in to see if it will kick over and run again. We'll have to go back and forth with some troubleshooting to narrow it down.
Jan 29, 2007 | Smeg FC40RX Bottom Freezer Refrigerator
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
