Question about Panasonic KX-T7730 Corded Phone
I have a problem programing T7730. I have 5 extensions, (11,12,13,14,15) and i need to program if line 11 is busy,then 13 should ring,and if 13 is busy then 15 should ring,and have to cancel ringing of (14 and 12). My head hurts how hard i tried and failed!! :(((
  • srdjan andrejic Feb 05, 2010
    12 and 14 are special phones that should ring only when call is transfered to them (they should be able to make calls normally)
  • 201 Answers
SOURCE: Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Posted on Jul 17, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: cacelling forward
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Posted on Feb 04, 2008
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
Posted on Feb 17, 2008
Centernet
  • 38 Answers
SOURCE: Transfering calls
It sounds like your dealer didn't properly set up incoming call distribution groups. They probably just gave you the "default" settings and left you a manual, took the check and said, "Good bye, and good luck!"
I think you mean transfer instead of forward. Your incoming calls should go through an Incoming Call Group - even if you're the only person in the group. Then you can handle the calls as they come in, transfer them out, and if you run out of buttons the system can even queue the calls up until you can get to them.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
cnavarro
  • 2460 Answers
SOURCE: i have connected the pabx to one external line, i
On this sied of the pond we use 408-410 for DAY/NIGHT/LUNCH ringing. All bets are off if you have an ISDN trunk.
Carl
Posted on Mar 19, 2009
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
I have two lines. When I am on the phone and there is a call on the second line they phone does not ring on. I would like it to ring or ring on the other extension.
It requires both programming and a feature code. First of all, does the second line ring any phones when a call comes in on line 2 alone? If it doesn't, you need to program the appropriate 40x (407-409) sections of the system. If it does and only one phone rings, again you program other phones in the same program. Also, you can turn on call waiting on a busy set with a 7311/7321 on a TA system. That will soft ring the phone when you're on it if the line is programmed to ring in the first place.
Carl
Dec 22, 2010 | Panasonic KX-T7730 Corded Phone
My phones only light up on my panassonic business phones
If you have a PTPM or the maintenance console, you can program ringing. It's a dealer only product in the U.S. Incoming calls are made to ring ICD (incoming call distribution) groups where the ringing is controlled per extension. In our version, even the manager does not have access to that level of system programming.
Apr 05, 2010 | Panasonic KX-T7633 Corded Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
How do I program alucent Pasartner 18 phone-- new line has been added by verizon but we need to program phone to accept the new line
you will have to go into system programming.
#301 will add it to each extension.
If you have no special ringing programs on all extensions (all phones ring immediately) you can do the initial line programming, #104, but that will reset all lines.
Oct 14, 2009 | AT&T Partner 18 Phone (315805B)
I need an extra line to ring on my phone
First, you'll have to know what the line number is in the system for the new line.
To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
The display should say for example L025:LINE 05.
The port number of the example is port 025.
write the port number of the new line down for future reference.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
press the release key when finished
Sep 29, 2009 | Nortel Meridian M7208 Corded Phone
Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
Multi line system and phone still rings while I'm on another line
courtney,
Unfortunately if the receptionist is using priority call (f69) there's not much you can do. Priority call is an administrator programmed function that overrides when your on a call and when the set is in do not disturb. Maybe bribing the receptionist might be in order.
Feb 12, 2009 | NorStar Meridian M7310 Phone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
