Question about Samsung AS18A6RB Air Conditioner
Leaking Air Conditioner
My Aircon is icing up and dripping water over everything under it, I've cleaned the outer filter and blown out any dust inside, is there anything else that needs to be done?...any other filters that need to be cleaned/replaced?
    Problem Solver:
  • 5 Answers
If your filters are clean and the evap coil is not plugged. the unit should not be icing up. If icing occurs when all components are clean, there is an issue with the refrigerant charge and should be looked at by a professional
Posted on Mar 15, 2008
  • 236 Answers
Try also to check if your evaporator fins is clean cause even if your air filter is clean will still present with dirty fins.
Posted on Feb 20, 2008
Operation light is red and my Fujitsu split type air conditioner is drippy and icing up. model asu1201 serial AJA006007
Most likely low on refrigerant. This will cause the evaporator to ice up which will then drip in side the room as the outer surface melts. It also causes less air flow through the heat exchanger which exacerbates the problem. You need to find the source of the leak which is probably at one of the flare joins. Unfortunately, I don't have a service manual for this model so cant tell you what the error code is. Consult a local tech.
Jul 14, 2014 | Fujitsu 24C1 Air Conditioner
Carrier split unit aircon mdl 42P100c has water dripping from the unit mounted internally onto floor.
Due to non maintenance of a/c. Col and air filter dust blocked. Due to this, some time ice formation over the coil will be there. Clean air filter, coil and blower wheel. And also drain pan.
If you see any ice formation over the coil after service, it's meant for short of gas. Thanks.
Jan 11, 2011 | Heating & Cooling
Water drips from the centre and regularly hear a grating sounds
Indoor coil is forming ice and then defrosting. It's due to blower wheel,coil and air filter are dust blocked. clean it. Less rpm of indoor motor. replace capacitor.
Jan 05, 2011 | Mitsubishi MSH09TW Air Conditioner
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
What could be wrong with my aircon unit? Water dripping sound
Your coils need cleaned, and change the filter too. make sure drain is not cloged also.
Jul 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
448 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
