Question about As Seen On TV Wonder Steamer Kit Iron
Wonder Steamer "As Seen on TV", I loaned it out and it came back without the instruction book. The bottom says to "scale and clean" before every use, I need to know how. Thanks for your help, Mom of Six
  • dwaa2000 Feb 27, 2009
    I have no instruction book for my wonder steamer. How does it work?
  • Anonymous Mar 19, 2009
    Need directions. I've lost them. Thanks.
Have lost the cord & instruction booklet for the Wonder Steamer.. Can you help?
Posted on Dec 23, 2009
How can I get my steamer to work again? Orange light comes on but nothing else
Make sure you didn't knock off a wire to the heating element when you had it open. Also put a couple of cups of whitevinnegar in it and leave it for an hour or two. This will dissolve the scale build up. If it doesn't get hot thenthe element is probably burned out. There is a limit switch held against the tank too. It can stop the heating element if it goes bad.
May 29, 2014 | Rowenta IS9100 1550W Precision Valet...
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
My clothes steamer won't keep putting out steam stops after about 5 min
It sounds like it is shutting off on high temperature because of a line/scale obstruction. You may need to descale it. Use CLR (available from home improvement stores or supermarkets) or something similar. That should get it back in operation.
Jun 26, 2011 | Yamata PSS-2001 Iron
We own a SmartLiving Steam Mop, and have really enjoyed it. It suddenly quit steaming. We tried putting vinegar through it in case it was hard water deposits, but no luck. Any siggestions?
yep i have one,,,,,dont use vinegar,,,thats good on chips? no good in steam mops!
go get yourself some kettel cleaner ,,,the stuff for cleaning the lime scale off the inside of your kettel,,,,mix it up in a jug with warm water,,,,and tip that in your steamer,,,dont breath the fumes?
this will clean out any lime scale for you,,,next time fill it with rain water,,,,there is no lime scale in rain water?
Nov 27, 2010 | Hamilton Beach Steam Excel 14770 Iron
Water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Mar 14, 2009 | Rowenta Compact Steamer - White
My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Dec 23, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Rowenta Steamer
Same thing with my daughter's..any solution out there?
Jun 22, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Irons Logo
460 people viewed this question
Top As Seen On TV Irons Experts
Are you an As Seen On TV Iron Expert? Answer questions, earn points and help others
