Question about Zanussi 24 in. DE6544 Built-in Dishwasher
Zanussi DE6854 Not draining and flashing lights (Drying and End of Program)
3 Suggested Answers
  • 833 Answers
SOURCE: ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Posted on Dec 11, 2007
SOURCE: Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Posted on Sep 25, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
hi
Oct 07, 2009 | Electrolux Dishwashers
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Dec 06, 2007 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi 24 in. DE6544 Built-in Dishwasher Logo
119 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
