I have a wall mounted split, 30 type model/capacity.Possible 10 year old. I have a damaged internal blower/fins damaged. What's a replacement part worth, blower/electric motor Are they readily avail. any diagrams/steps to show repair I am in Melbourne victoria Australia
  • 506 Answers
How many BTUs is the unit? If it is quite large I would possibly consider getting it refurbished however if the unit is 6000 BTUs and under I wouldn't waste your money. You can re-form the fins with a fin comb, those are pretty cheap to buy and as for the motor you would have to get a part number from the motor itself. What is the make and model of the unit in question?
Posted on Feb 04, 2010
One year old Panasonic Split system only blowing air
The compressor may possibly still be working but has no more freon. Ths may be caused by a leak.
Nov 16, 2013 | Panasonic Single Split Wall Mounted Air...
My 10 year old whirlpool super capacity 456's right front control knob started to burn with flames shooting out. Disconnected plug from wall and have been using lighter to start burners. Any idea as
there's a wiring harness with 4 or sometimes 5 switches depending on the model you have that slides onto the valve so when you turn the knob that burner will light,the switch most likely shorted out.if this is a regular stove with an oven and burners on top look down at the bottom,under the oven door you'll see a draw,open the draw and look on the frame not on the draw on the frame and you'll find a tag with the model and serial number on it,send the model number and i can look up your model.
Nov 20, 2011 | Kitchen Ranges
Middleby Marshall 360 pizza conveyor oven is making clanking noise by circular fan grate in back bottom left of oven. Please help
Is it the rear of the oven or the left side?
  • Rear of the oven, it is a obstructed or malfunctioning axial fan. Replacement cost $10-$20 - 30 minutes labor
  • Left side of oven, possible main blower fan malfunctioning. Depending on type of motor "S" or "Q". It might be the mount or a bearing wearing out. Replacement motor $200-$400, motor shop rebuild instead $150. Squirrel cage will need to be removed if damaged $100-$300. Labor 2 hours, if you know what you are doing, 4 to 6 if this is your first time. Check your heat slinger also. This might have come loose.
Call me for parts or further info. I have been here before.......
Marcus Bramhall
Shimmmer LLC
318.202.2022
206.769.4466
Feb 17, 2011 | Ovens
I have a wall mount 25000 btu empire. It keeps clicking on and off trying to light up. after about 4 or five tryes it starts, runes for a short time and shuts off. A funny noise comes from the burner area....
You're heading in the right direction. Especially, with a 10 year old heater that's never been cleaned.
Using a vacuum (a shop vac is great for this) that has a hose and brush attachment will do the job. Also, canned compressed air with a straw nozzle (like you clean your computer with) can be used to blow out the pilot tip and reach areas the vacuum can't.
After you've cleaned the heater, check for wear and damage to any of the internal parts. Especially, any wiring that may look burned or frayed. Also, be sure that the exhaust vent damper is working properly and the exhaust vent piping is free from obstructions. The clicking you heard may have been from the automatic safety damper switch.
If after 10 years you can't find your Owners Manual, here's a link to it. It will assist you any cleaning the unit and spot any problems.
http://www.empirecomfort.com/EMPIRECOMFORT/pdf2009/manuals/12425-1008GWT.pdf
Good luck and remember to clean the wall heater annually.
Rich
Feb 11, 2011 | Empire GWT-25 Wall Mounted Panel Heater
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
The serviceman said we needed a thermacouple for GloWarm Model FBS-28000LP wall-mounted propane heater. Where can I buy one?
Bring the old one to a good hardware store or home center, they should be able to match it up. Find a store that sells heaters and you will have a better chance.
Oct 23, 2009 | Desa International Blower Glow Warm Wall...
Best height of inside unit of a split AC
which type of mounting is suggested wall or ceiling, if it is suggested that wall mount is nominal then the height is optional, mount it as high as possible. If ceiling mount is suggested then closet to outside wall as possible
Jul 26, 2009 | Friedrich QuietMaster RS10J10 Air...
Kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Jul 22, 2009 | Plumbing
Problem with the internal electrical transformer
it is probebly a 50 va transformer 220volt or 115 if the inside is gas
Jan 23, 2009 | Heating & Cooling
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
