I have a Kenwood KXW 4060 Audio Cassette Deck. The ?A? deck (playback) is fine but on the ?B? deck (record/playback) the tape occasionally runs too fast. The problem seems to be most likely to occur at the beginning of a cassette and on some cassettes more than others. I am confident that this is not due to tape slippage but to the capstan running too fast ? perhaps twice the normal speed. Additionally even at normal speed there is pronounced flutter. The DC motor is designed to run at double speed when in the ?high speed dubbing? mode. It occurs to me that the ?servo control? may not be operating properly and would appreciate any advice as to how I may correct this. I have the circuit diagram and operating manual as PDFs but can only forward these by email so would require your email address. Address here is ronrsmith5@hotmail.com Ron Smith
  • 3,247 Answers
Hi there, I have responded to this problem in the past but have had no comments back.
Please confirm if you have checked the high speed dubbing switch is not playing up intermittently. Also as a first step it might be worth replacing the electrolytic capacitors in the servo circuit.
Is the problem with B deck same whether you are playing or recording tape?
Have you cleaned the play/ record heads and also replaced the drive belt at some stage?
Please check my previous posting to you on this as well.
Posted on Feb 15, 2010
  • 506 Answers
Are you hearing high frequency flutter or low frequency flutter. This will be the key to figure out what is happening. Please let me know we can then go from there. Look forward to hearing from you Ron.
Dave
Posted on Feb 12, 2010
  • 1,428 Answers
It could be some ic's are gone bad. Short circuiting.
Good luck.
Forward PDF to titilayosodipe@live.com
Posted on Feb 13, 2010
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
On Kenwood CT 2050, tape speed varies near end of reel and stops prior to end of reel
Many cassette units have trouble handling 120 min tapes. You seem to have taken care of some of the problem areas but in my experience I would suspect the belts have stretched or aged. If this an older deck, the motor may be weakening. It can be the source of the problems you describe
Sep 21, 2012 | Kenwood CT 2050 Stereo Dual Cassette Deck...
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
My GO-VIDEO model GV-4060/GV-4600 dual-deck video cassette recorder has a on-screen display message that says "ERROR". I have turned the power "off" then back "on" to clear...
The loading deck is out of sequence Check to see that the loader is in the correct position. reset & it should work properly
Nov 30, 2010 | Televison & Video
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Gunk fused to record & playback heads of Onkyo cassette deck
The best cleaner for heads is Servisol Video 40. You can get it from Maplin's UK or Amazon.
Mar 19, 2009 | Onkyo TA-RW244 Single Cassette Deck
Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Jan 31, 2008 | Audio Players & Recorders
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
57 people viewed this question
 Grubhead
Grubhead
