Question about Nokia 9300 Smartphone
Using wireless lan on nokia 9300i
I m unable to set & use my home modem for using wireless lan with my nokia 9300i i m having bsnl wifi modem at home please suggest me something
  • Anonymous Feb 07, 2009
    please help us
    President:
  • Nokia Master
  • 511 Answers
U need a wireless signal provider such has router so only u r unable to connect it...
Posted on Sep 01, 2009
Nokia siemens router 1600
Most home routers have a reset in the back. Hold it in till it cycles this will clear all custom settings. Then just Google your make and model. About.com has many of the most popular makes and models.
Jun 06, 2013 | Computers & Internet
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
I want to start internet in 4 computers what can i do for. i have a bsnl broadband connention. PLz help me
Hi Friend, In this case I would recommend you to please check if the BSNL modem is the wireless modem or the Wired modem. If it is a wireless modem then you can connect your system wirelessly to internet , provided that the laptop has the wireless card in it.
If it is a wired modem then you can connect your system with the LAN cable to that modem in each slots to get connected to the Internet.
Dec 09, 2010 | Intel Computers & Internet
I am unable to connect my Samsung monte s5620 with my bsnl teracom wifi modem. Although, I can connect it to my pc.
1.Verify the network key you have entered in the WIFI settings.
2. Check the Encryption type is TKIP.
3. Uncheck static IP in advanced settings.
4.Protocol must be set to HTTP in WIFI settings.
Nov 16, 2010 | Samsung S5620 Cell Phone
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
My dataone WA3002G4 (BSNL) modem is not connecting to internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Non connectivity with thomson tg585 v7 modem with bsnl broadband.
what is bsnl broadband if you have thomson to acsess the setup and all it freater just type speedtouch.lan in your browser this may help you
i think
Jul 02, 2009 | Thomson RCA DCM245R Modem
I m havin BSNL ADSL2+ DNA-A211-1 modem..i don know how to connect my laptop wit modem in wifi mode..pls tell how to configure n connect it..modem has ethernet port oly not having usb port..pls suggest some...
Secured Wireless is better than a unsecured one. Configuring a secured wireless network easy.
· First Check it the Wireless is turned on in the modem.
You must see the wireless light glow on.
Wireless LAN (WLAN) should be Enabled before configuring the wireless network
· To make sure, if the WLAN is enabled you can check the WLAN light glow.
· If it is off, then you can be sure that WLAN is disabled.
May 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Nokia 9300 Smartphone Logo
529 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
