Can not get access to menu ON ROUTER 2800G vigor. Have correct IP address of 192.168.1.2 but page will not load. Will a reset cure the access problem. Router is currently providing internet access
  • 644 Answers
A reset would resolve this isssue but it would be reset to factory defaults, so you would probably have to get in contact with your isp to set the settings back for internet access.
When you type the ip address do you get a user name and password window up or just nothing at all? You try 192.168.1.1. And see what happens.
Posted on Feb 04, 2010
I am trying to find my password for my d-link di-624 router-i have wireless setup but i have lost my password to load on my laptop to connect to the internet. I have a qwest dsl modem with wireless...
First connect your router to computer with ehternet lan cable then go to network adapter property.For that press windows key +R so you can see run type in run "ncpa.cpl" then press enter then you can see network adapter property. go to your network adapter tcp ip property and enable "ip get automatic" then it will get ip from router if dhcp enabled.Then go to command prompt type "cmd" in run so you can see command prompt.Type in prompt "ipconfig" then press enter then you can see all ip address gateway ip is your router ip address .Note that ip then type that ip in address bar of internet browser then you can see your router page.Also the default ip address to access router is http://192.168.1.1 or http://192.168.0.1 Try these ip hen you can see router page .But if you are still not able to see router page with above ip then need to reset it.press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . After seeing router page type user as "admin" and password as "admin" or blank or "1234" or password. then you can see configuration page of routerThen click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password.If you have to reset router for access it then also need to configure WAN ,wireless,DHCP on router . Let me know if you need further assistance. Thanks for using FixYa
Oct 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Step 1:
Step 2:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Configuration page doesn't load
1. can you ping the router? go star>run>cmd and type ping 192.168.0.50
if the ping times out or says it's unreachable, check your network connections (cables are fully seated and there leds are blinking properly)
2. try to type 192.168.0.50 on the address bar and hit enter, did you change the ip address on the router before?? if you did and can't remember what ip address you gave to it you may need to reset your router.
3. try the same ip address in another browser (IE, chrome, firefox), Make sure your browser has Java, JavaScript, or ActiveX enabled. If you are using Internet Explorer, click Refresh to be sure the Java applet is loaded.
4. are you using the right the correct user name and password? enter 'admin' (lower case) and hit enter or the password you may have configured, if you can't remember what that was reset your router.
you router's manual can be downloaded from here
good luck
Nov 22, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
