Question about Sony Cyber-shot DSC-T10 Digital Camera
The lens keep vibrating when I switch on the camera and so all pictures I take are now fuzzy and out of focus :(
    Habit-Forming:
  • Sony Expert
  • 153 Answers
Actually this problum is in lsv assy so please go to your nearst sony service centre & fix your problum
Posted on Feb 05, 2010
How can I keep the picture sharp when zooming in macro
When you zoom in macro with a Coolpix camera, you must change the camera to subject distance to compensate because as you zoom in and out, the depth of focus of the lens changes dramatically.
Jun 10, 2014 | Nikon COOLPIX Cameras
Fixing a seized AF motor
One theory on this is that the camera's software or settings may somehow be corrupted, so you should go through the process of resetting the camera to its original factory settings. If that does not clear up the problem, try another AF lens and conform whether the problem is the lens or the camera body. If the camera is not focusing another lens, then you may need to clean the contacts or look for some sort of damage.
If it turns out that it is the lens, the best solution is to send it to Tamron for service and see what they can do about it.
If you cannot send it to Tamron, you ought to see whether it is something as simple as some sort of internal dust or dirt collection blocking the mechanical switches and functions of the lens.
Start with making sure that you have a fully charged battery for the camera or AC power adapter for the camera. You do not want any of the problems with the camera to be related to having too little voltage available.
Make sure that the camera's power switch is switched off. You do not need to have the battery or adapter connected just yet.
Next, with the lens off of the camera, switch back and forth several times, firmly, between AF and MF and switch the vibration compensation off and on a few times. Of course, do not drop the lens. Also, unless you need the zoom ring locked, you may want to make sure that the zoom ring lock is fully off. While you are doing this, or after switching back and forth, check the electrical contacts on the lens and the camera body. If anything looks even a little less than shiny, clean the contacts.
With the camera's power still switched off, put the lens back on the camera.
Either put the battery in the camera or connect the AC adapter.
Set the lens to AF with vibration compensation off.
Switch the camera's power on.
Try getting the camera to automatically focus on something. If it works, turn the camera's power off, then switch vibration compensation on, then turn the camera's power on and try again. It may be fixed, at this point, which means that you can ignore the rest. Otherwise:
Turn the camera's power off again and switch to manual focus. Turn the camera's power back on and rotate the lens's focus ring (gently) all of the way through the focal range two or three times. Try taking one or two pictures, just to be sure that everything is working in manual. Turn the camera's power off and switch the vibration compensation, then turn the camera's power back on. Gently rotate the focus ring all of the way through the focal range two or three time, and then take two or three pictures to verify that everything is still working in manual.
After that, turn the camera's power off and switch back to AF with vibration compensation off. Turn the camera's power back on. Try to get the camera to automatically focus on something. If it works, then turn the camera's power off and switch vibration compensation back on again. The turn the camera's power on and try to get it to automatically focus on something.
If all of this works, than you should be okay with it as it is. You may still want to send the lens in to Tamron to get it serviced, in case the problem was some sort of lint or dirt getting caught up in the gears or servo that moves the lens through the focal range.
If it does not work, you could try to force the lens to re-engage the autofocus servo. It will probably void your warranty, if you still have one, so you are better off send it in to Tamron for service, first, before trying it. Also, as the manual and common sense would indicate, if you try to force the lens to adjust its focus ring while it is switched to AF, you could easily break the mechanism in the lens.
With that being said, some people claim that they got their lenses to return to proper autofocus by leaving the lens switched to AF and trying to rotate the focus ring manually. One person says not to "force" it, his just took a "firm push". I have not tried this, so I do not have advice on how much force may work or how much will damage the plastic bearings, gears and teeth inside the lens.
May 04, 2014 | Nikon D60 Digital Camera
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
I have Sony T-200 for more than 2yrs. It has been working alright. Now when it is switched on it vibrates and the picture you get is out of focus?There is no vibration when viewing pictures.
hi, your camera has IS unit get defective cause vibrate noise. and out of focus. It will require realignment or lens unit assemble or replacement of the lens unit. your local repair shop would charge around $65 to 135 depend on what they really want to charge. Good luck with you and best regard!
May 22, 2011 | Sony Cybershot DSC-T200 Digital Camera
The picture quality is very poor. Picture is fuzzy.
Did you turn the ring on the camera itself? The camera does not automaticaly adjusts itself. You must turn the lens to focus manualy.
If nothing works and you just bought this camera, call microsoft and they will help you more.
Mar 05, 2010 | Microsoft LifeCam VX-3000 Web Camera
After a few thousand really sharp pics, all of a sudden the shots are coming out slightly fuzzy, hardly noticeable at normal resolution, but especially evident when enlarged. Tried several different...
If the AF is set to release then the camera will release the shutter before focus is attained. Set it to focus only and see if it improves. Don't leave it like that, you will miss pictures.
Shoot some pictures with the center AF point only in single release and see if the focus is consistently landing in front of or behind what you wanted in focus. A penny on the sidewalk shot at a 45 degree angle in aperture priority with the lowest A number possible is a good quick one. For super fine tuning with a f2.8 or faster use a fuzzy plant branch like a tomato plant. If whats in focus is always in front of or behind what you focused on then you need too adjust the focus(back focus) in AF fine tune until it lands where it should. It's an annoying process that involves shooting, adjusting, shoot again, see if its better or worse, adjust, shoot and repeat. On zoom lenses use the middle on the zoom range because it will usually go from back to front focusing on the long and short end. The camera remembers each lens and the process must be repeated for each lens.
Last thing I can think of is the one that no one wants to hear and is most likely the problem, Camera Handling. People have a tendency to get sloppy after getting use to a camera. I have noticed that the VR lenses don't like people that stab the shutter button. It wants to remove fine vibration and a harsh stab makes it jump back to center and if the shutter opens at the same time it will put fine motion blur in the picture and looks out of focus.
Oct 03, 2009 | Nikon D700 Digital Camera
When the camera is turned on, the lens vibrates briefly for 4 sec.It doesnt matter if its in Auto or manual focus. It happens while turning off the camera as well. I have sent the camera to the Sony...
It is likely to be an issue with the auto focus in the lens. You will get the grinding noise even if you switch the camera on in manual focus, but not if you take pictures in manual focus.
Oct 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
All of the pictures taken are very fuzzy no matter what you do
check to see if a flower appears on the screen. If it does then the camera is set to macro and all your pictures except close up will be fuzzy. To switch macro off, move the ring on the front of the camera till the arrow is pointed straight down. I was having the same problem. Wasted a whole day of vacation pictures. That was what fixed my problem and I hope it fixes yours too,
Feb 17, 2009 | Samsung Digimax A503 Digital Camera
Fuzzy/out of focus pictures
This may sound kind of obvious, but have you cleaned the lens?
It's common to get finger prints or other marks on lenses, which result in blurred pics.
Jan 05, 2008 | Olympus Camedia D-540 Zoom Digital Camera
Sony Cyber-shot  DSC-T10 Digital Camera Logo
198 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
