Kodak Brownie Super 8 Projector
Hi.
I have a couple of these projectors which I can't seem to get working.
I have loaded a reel of film in and turned the switch to project but there is no movement. I have tried changing the fuse, so it isn't that.
Is there something I am missing?
Would appreciate any advice you can offer.
Thanks
  • 682 Answers
In slide projector smooth movement of mechanism is rule number 1 .1-spray contact lubricant cleaner on forward and backward switches and press them many times.-open it and clean it with air blower and clean piece of clothes.apply good type of light grease in levers-cams gears-confirm all mechanical parts is in good condtion.change any broken part from nearest store.
best regards
Posted on Mar 01, 2008
Repair manual for DeJur 747 8 mm projector
David,
I'm not sure if a "repair manual" was ever printed? I did find mentions of the "User Manual" but that it!
Here is a VERY interesting site for you!
8mm FILM PROJECTOR REPAIR Super 8mm MOVIE PROJECTOR REPAIR RESTORATION...
See what you think!
Anthony
Apr 15, 2018 | Photography
Hi, my dad's Kodak Brownie 8 A15 regular 8mm film projector has an issue with the knob. It will turn to the rewind position but not Project. Does it have to be pushed in ? I hate to force it.
http://www.grantmillar.net/kodak-brownie8-manual-15-g-version1.pdf. Doesn't seem to need it. Check to make sure the knob hasn't turned ie off is project and rewind is off and there is another setting after rewind.
Nov 18, 2014 | Kodak Office Equipment & Supplies
Control knob on kodak brownie 8 will not turn
Hi Don,
I have the same problem with my dad's Brownie 8 Model A15 projector...however, the knob will turn to "Rewind", but not to "Project". Did you ever get yours to work? Thanks! Jon
Sep 02, 2013 | Kodak Cameras
? Is the sprocket wheel in the middle of the projector supposed to move? The film seems to be locked up in there, and only the few inches of film in the gentle curve above the lens seems to feed thro
I know this post is old but I found a solution. The axle going to the sprocket is locked up with something sticky. You have take out the two screws holding the white plastic piece around the sprocket. Then loosen the small bolt on the big wheel on the other side. Remove the big wheel. Try to push the axle through to the other side. If it doesn't budge easily, hammer it out. That's what I had to do. Then clean it up real good with solvent, like alcohol. Lube it with grease and put it all back together. Worked for me.
Jul 19, 2012 | Kodak Antique Brownie 300 Movie Projector
I have film on little 3" reels. i think they are super 8. i have the mx33 projector. i don't know how to load the film. does it go from the top or the bottom. through or over the 2 round...
all projectors thread differntly. i can transfer the footage to DVD for you. Call me for price, 718-268-6440 continental photo, 10am - 6pm mpn - sat
Jul 31, 2011 | Cameras
Eumig 610D Super 8 projector take-up reel not engaging at hub so will not rotate. Hub will rotate, not the reel. Perhaps worn key?
I think the Eumg 610D was a dual guage projector, capable of showing both Standard 8 and Super 8 films. (I'm basing my comments on the S810D I have in front of me, its sound "big brother").
To move between formats, there were two cogs internally that had to be changed, a film gate (two parts), and two adaptors/liners inserted into the centre of the film reels that transformed the centre from "a fat one" to "a thin one".
If the take up driver cog is rotating, but the reel is not, check whether the adaptor is in place.
You can see what they look like on eBay....
http://cgi.ebay.com/NEW-Super-8-Movie-Projector-Reel-Adapter-Film-8mm_W0QQitemZ170450331975QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27afa1a947
If the rear driver cog is not rotating, then it might be a worn/defective drive belt, in which case leave a further comment and we'll explore that.
Hope this helps
Jan 02, 2010 | Cameras
How do I open my Kodak Instamatic M70 projector?
I have a Kodak Instamatic M70 Super 8 movie projector. How can I stop the film from continously jumping? I have adjusted every nob and looked inside to find nothing out of the ordinary.
May 16, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Belle & Howell Super 8 Projector model 254RS loading problem
Don't have the motor switch in the still position when loading -make sure it is on FORWARD. Look at the little holes in the film and make sure the film is on the same side as the little grooves on the drive gear.
PS -let the bulb cool off before try to move the projector ,the bulbs are very expensive and hard to find.
If you do use the still position to view a frame do it for just a few seconds or the bulb will burn the film. Good luck- Tom.
Jun 21, 2008 | Bell & Howell Photography
738 people viewed this question
k24674
jasbo
jasbo
