Question about Refrigerators
Pooling of water in fridge compartment of my Neff fridge/freezer
In the fridge compartment of my Neff fridge/freezer K5654X1GB 'bubbles' of water form at the top and then drip down to form pools of water at the bottom of the compartment which do not drain away.What can I do?
  • 619 Answers
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
Neff fridge/freezer feels hot down centre between the fridge and freezer compartments, making the door see feel hot too
Check your condenser fan motor for proper operation. It is located beside compressor.
Aug 28, 2017 | Neff Refrigerators
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is pooling at bottom of fridge, comes out from area at top in the back behind light.
If your freezer is above your refrigerator compartment, this may be your problem:
Your defroster (automatic) may not be working properly. Ice is building up in freezer drain, damming up the drain hose to the outlet. Water then overflows down into the refrigerator compartment.
Nov 03, 2010 | Whirlpool Refrigerators
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Whirpool refrigerator ET21PKXGN00 poor cooling refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 15, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water keeps pooling on the second shelf in the refrigerator, and I can not find the source.
Water collecting inside a fridge (that doesn't have a water dispenser in the fresh food compartment) is usually a sign of a clogged tube that directs water collected during the defrost cycle of the freezer coil. The defrost heater melts frost / ice that collects on the coil and water drips into a pan directly under the coil in the freezer compartment. The pan has a tube that allows the water to flow into a pan at the bottom of the fridge, where it is generally evaporated by the heat of the compressor.
You'll have to access the coil and pan (probably behind the back wall of the freezer - but check your model first!) and clear the obstruction from the tube. It is not uncommon for bacteria, mold, etc to grow in the tube. After clearing with a blunt flexible snake - run 4 - 6 ounces of a 10% bleach 90% water mixture to kill any growths remaining in the tube.
Sometimes, ice can form in the top inch or two of the tube, too. A turkey baster can be used to direct hot water into the tube to quicken the thaw process.
If there is water dispensing in the fridge, check all lines and filters in the compartment for spits, cracks and leaks. Repair / replace parts as needed.
Do not perform these steps with the power on!
I hope this helps!
Oct 28, 2009 | Refrigerators
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
Refrigerators Logo
598 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
