Question about Gigabyte GA-8SIML Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get three short beeps repeated continuously until switch power off at wall as power switch on front panel has no effect. Allso flashing front panel blue LED.
  • 644 Answers
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Posted on Feb 04, 2010
  • pandgcs Oct 18, 2010
    Just had the same problem and i realised that a component had burnt out (browning on the board) replaced it and it works now, also had to change a few capacitors as these had blown.
    i think the component is labeled as D20 near the atx power in socket
Ga-g41m-es2l xp install problem
do you have enough memory (RAM) ? .freezes means to little memory.
Jun 09, 2013 | Computers & Internet
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Wont accept bios update that was sent from packard bell after total failure keeps asking for bios file. also clear cmos feature on board three pins one with white square which i assume is pin 1 but header...
Ga-8SIML is a generic gigabyte mobo and does not need a packard bell bios. you could goto the gigabyte site and get latest from there. If your PB displays a logo at the start then its likely that you will lose that logo as the generic bios will not know it was fitted to a PB machine but thats no hardship.
Be sure to check the board version. version 1.0 takes one type of bios ver 3.2 another and they wont load into the wrong versions of the board. F12 is the latest non beta. I just did two of these recently so i know F12 is ok.
suggest you visit gigabyte site anyway just to check how the bios should be blasted and which version supports which mobo model no..
Aug 13, 2010 | Gigabyte GA-8SIML Motherboard
Can i upgrade my packard bell 4340 imedia pc,it has an athlon xp 3000+ barton cpu,768mb ram in 2 slots,graphics-radeon 9200 series
You can upgrade the memory to maximium of 2gb of ram 1gb stick of ram in each slot. The memory you will need DDR PC 3200 184 pin.
You can also upgrade the hard drive for more space or buy an external drive to store files.
Jul 20, 2010 | Acer Computers & Internet
Hi ive got a GA-8TRC410MNF-RH Gigabyte mobo from a packard bell IMEDIA MC 2559 PC The mobo's P/N : PB34316801 I got a new case for my son to build a PC for the first time and we got this mobo from ebay...
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink
http://support.packardbell.com/uk/item/index.php?i=spec_SeagateTonkaII_Serial&ppn=PB34305801
Feb 14, 2010 | Gigabyte GA-6WMM7 Motherboard
Firstly you check your RAM by use another RAM and then check it is working or not, after that if display is not coming then check your processor it is fitted properly or not if it have fitted and display is not coming then *********** board's winbond chip have been damaged.
Repair it from a techinician.
Regards
Ashly
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Packard bell imedia 3034
After reading a ton of posts you may be correct, your board is dying or is dead.
An easy way to get your data off your old Hd to your new Hd would be to connect it directly into the new PC internally.
Just like you would a new drive only you would set the old drive as a slave. Here is your 3034 link.
http://support.packardbell.com/uk/item/index.php?pn=P842025601&g=1400
The motherboard in this 3034 is Gigabyte, GA-8SIML-NF7, shown at this link: http://support.packardbell.com/uk/item/index.php?i=spec_columbia5p&ppn=P842025601
There is almost no chance of you finding this board its just too old. There are boards at this link that will handel all of your imedia 3034 parts, motherboards.
http://computers.pricegrabber.com/motherboards/p/40/form_keyword=motherboards+478+socket/rd=1/mode=g_us_b_s/skd=1
Hope this helps you Jim!
Please vote...
Jan 18, 2008 | Intel Motherboard
Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
Jan 03, 2008 | Packard Bell (090317) Modem
Gigabyte GA-8SIML Motherboard Logo
1,479 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
