Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Error 3802 comes up. Tried switching off and re-starting. Menu comes up ok but when I try & print or copy, error message re-appears! Help
Found the answer to the problem on the Kodak support site.
Changed the black print cartridge.
Thanks for your help anyway...........
Posted on Feb 05, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
How do i clear message c2558 for the konica minolta bizhub 215
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Feb 24, 2014 | Office Equipment & Supplies
Hi I have a brother mfc 5440cn and it fails to print but comes up with an error 50 message. How can i solve this?
Where does the Error message appear? is it on the printer or the PC.
Try a test print from the printer menu
Press Ink
Press up or down to select 'Test Print'
Press up or down to select 'Alignment
Press menu/set
press black start or colour start
The printer should start printing. If this prints ok then the problem is likely to be with the comms between the printer and workstation
Sep 02, 2011 | Brother MFC-5440CN All-In-One InkJet...
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 18, 2010 | HP Photosmart C7280 Printer
Please note that I pay $9.99 each month for using this service. I am trying to print 13" x 19" full color, RGB, using Photoshop CS4, from an iMac (Snow Leopard) to a Canon Pro9000. The error I...
The pro 9000 will make that switch for you unless the front switch is bad. You have to raise the front feed tray and make sure that the indicator light comes on and then you are ready to feed from the front tray. The back has to be open as well so the printer can draw in the paper all the way in from the front to the back and then start printing. You shouldn't have to specify in the dialogue box, as the printer knows when it's set up properly for the media you select.
Dec 19, 2009 | Office Equipment & Supplies
Printhead Error 3802 I have the Kodak ESP 5 all in one printer. It started printing blank pages a little while ago. Sometimes if I tried to print a couple of times it would eventually come out, so I knew...
3802 Mean Printhead Failuer
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it that again for (5x)
Tell this to kodak support
And tell the troubleshooting steps you did.
Mar 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp 3310 error
Thanks for trusting me sionah
Please do not go as per the error message you get.
Because the error message means a lot, like the error message you have 0xc18a0201, as per this message the unit has to be replaced (As i have worked with HP i know which error message has to be replaced or can be fixed)
But you can try this steps once. and i would not garauntee to fix your issue, But Better to give a try.
First of all unplug the power cord from the All-In-One from the printers end aswell as the power outlet.
Leave the cable unpluged for atleast 1Min.
Then connect the cable direrctly to wall outlet without the surg protector. and then connect it back to the All-In-One.
If the message is still there.
Press the # and * key in the All-In-One (The Display will say enter special key Combo)
Then press no 1, 2 and three.(The display will give some information) Ignoge the display.
Press the right arrow key till you see System Configuration Menu> Then press “OK.
1. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
2. Press and release the “OK” button.
3. Display should say “Hardware failure status: Clear. Press OK to clear”.
4. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
5. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
6. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
7. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
8. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
9. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
10. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
"PLEASE TRY TIHIS RESET ONLY ONCE"
If ir reoccures replace the unit. you can call HP and get the unit replaced. if it is Warranty.
If not you can also go for a Out Of Warranty Upgrade Option.
Good Luck
Sep 04, 2008 | HP Photosmart 3310 Printer
DCP-130c error 44 Please Help
error 44 dcp 130/mfc 240/440 etc.:
abnormally high temperature within print head.
You have two choices to TRY to fix it:
1. put in new carts. press menu then start copy b/w then  fourtimes arrow up button (AUB) quickly one after another.
press by help of AUB and OK:
7 - (Ok) 6  - (ok) 4 (ok) then start b/w copy to initiate the carts and let the machine do some power cleaning.
leave the maintenance mode by pressing AUB 9 (ok)  and 9 again.
2. Make sure that the ph is at correct position simply by pressing on it from top (power up machine. wait til ph runs to left side. unplug from power. simpl press onto the ph). replug to power.
If you still receive the error the ph is defective due to bad generic ink and needs replacing.
Mar 21, 2008 | Brother DCP 130C All-In-One InkJet Printer
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
97 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
