Question about Car Audio & Video
I have a 2004 grand am gt and shortly after i bought it the digital display on the factory monsoon stereo stopped working. the radio works but the display does not. i checked all fuses and cannot figure out the problem. what else could it be?
    Sergeant:
  • 306 Answers
The lightbulbs behind the display ave burned out. they are not easy to replace. requires radio diassembally and soldering new bulbs in place
Posted on Feb 07, 2010
How do i get my monsoon car stereo working again amp model # 2264744
I assume this is the one you put into your car (I answered the other question) if the radio anti theft is on you would need to get a dealer to run the serial number of the unit and get you the codes....assuming the previous didn't change it. You might come out cheaper changing the radio out with an aftermarket unit. Any unit can be used with the factory monsoon system. (I have done this in my 04 grand am monsoon). All you need is the radio of your choice and an installation kit and wiring harness adapter. You do not need the GM integration harness as long as you don't care about losing the door chime, key in ignituon chine, etc. You will need to run a switched ignition wire for the new radio as the factory one uses a data wire instead. It's just a matter of running a wire to a fuse in the drivers fuse box that comes on with the key. It's a rather easy installation and if you chose to have it done professionally should cost about $50 for labor.
Nov 12, 2016 | Cars & Trucks
Does a 2004 Pontiac Montana's radio have an amplifier? If it does, where would it be???
Unless the face of the stereo says MONSOON there is no separate amplifier. On a Non-Monsoon Delco system all four amplifiers are built into the stereo, Left front, Right front, Left rear, and Right rear. Monsoon systems do have a separate amplifier which basically boosts the output of the four regular amps in the radio. I can't imagine all four of those amplifier output chips going out at the exact same time. I would pull the stereo and check if all plugs are seated properly. If those were all securely plugged in I would (myself) inspect the inside of the unit for the cause of failure. For example all four amp chips pull power from a common point and if one chip had a severe enough short in it, this may have caused the power feed trace on a circuit board to overload (too much current going through it) and created an open which killed power to all four of them. Any good electronics repair shop worth their salt should be able to repair it if you can locate one willing to try. It may only need a circuit board trace repair and one amp chip replaced.
Mar 07, 2015 | 2004 Pontiac Montana
Converting Monsoon stereo to Alpine
Did you by any chance change your mids and highs amp??? Or just your radio???
Feb 24, 2013 | Alpine Car Audio & Video
How to splice factory speaker wires on 2004 grand am with monsoon
everything depence of system you putting in your car if u have no amplifire you connecting the speakers to radio as they marked i you putting one in, your speakers wires goes from amplifire to speakers there is no diffrent way of connection. also the diameter of your wires have to be adekwate to power u going to have in your system for optimizing the sound quality let me know if this help ya
Sep 22, 2012 | 2004 Pontiac Grand Am
Problems with monsoon radio in 2002 grand am gt
Try cleannig the contacts with a soft black lead pencil and see what happens
Mar 28, 2012 | 2002 Pontiac Grand Am
I bought a used 2003 Jetta for my daughter with only 12,000 miles on it. The Monsoon radio suddenly stopped working. The display shows FM 88.1 (the radio staion) but there is no sound and the radio is...
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
May 26, 2009 | 2003 Volkswagen Jetta TDI
04 trailblazer radio (Replacing factory with another factory)
take vehicle to local chevy dealer and have radio unlocked,only option
Jan 21, 2009 | 2004 GMC Sierra Denali
2004 dodge grand carvan
The stock radio? Or is it something someone put in there?
I would pull the radio out and check to make sure the harness is fully engaged in the back of the radio.
Nov 07, 2008 | 2004 Dodge Grand Caravan
Car Audio & Video Logo
254 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
