Question about Sun StorEdge L25 (SG-XLIBL25D-BASE) DLT Tape Drive
Lost Firmware Password on Sun StorEdge 3320 Raid
I am working on a Sun Storedge 3320 raid that was in storage for about two years and nobody remembers or recorded the firmware password for. We are trying to revive the raid and put it back into service but so far are unable to get around the firmware password. Originally we were trying to remap the luns on a set of hard drives that we hope to preserve the data on. Now we are working with a spare set of drives that we can freely overwrite or reformat. Is there a jumper setting like those on Windows based system mother boards that we could use to bypass the firmware password? (The StorEdge L25 below was the closest product available on the listed products. This is not a tape drive, rather a 12 disk raid.)
2 Suggested Answers
  • 1705 Answers
SOURCE: Can i get a SCSI
You shouldn't have too much trouble, they are a bit old hat but you should be able to get one from most PC shops/repair shops, some electrical retailers but I'd try ebay for the cheapest option.
Here's a male to male version on ebay:-
http://www.ebay.co.uk/itm/External-HD68-HD68-SCSI-Cable-60cm-/250734116201?pt=UK_Computing_CablesConnectors_RL&hash=item3a60eafd69
Just ensure what terminals you need at each end of the cable, there are various choices.
Posted on Sep 01, 2011
Can't see drives outside of raid
You may not be able to boot you drives outside of a RAID array depending on the RAID type (software/hardware) and configuration (RAID0/1/5). Generally a mirrored RAID1 should be bootable off of the RAID array. If you are using software RAID or a RAID0, you best bet is to update the RAID firmware, and if the data is accessible at all, transfer the data to another storage device.
Jan 24, 2012 | SuperMicro P8SC8 Motherboard
Can i get a SCSI Cable for Sun StorEdge DAT 72
Sep 01, 2011 | Sun STOREDGE DAT 72 DAT Tape Drive
Quatum M2500 with error code 263F and tape stuck in drive.
http://www.sandirect.com/documents/mseries_users_guide.pdf
Page 130 defines the error.
See the section on DLT cartridge handling and inspection.
Get this resource to guide you through the drive and tape mechanisms:
http://www.filibeto.org/sun/lib/hardware/storedge/tape/l280/pin-024.pdf
Aug 15, 2011 | Quantum ATL M2500 Tape Drive
No power on tape device. Re-plugged power cord and cycled the power switch.
Check for a replaceable fuse. Look on the back of the unit where the power cord goes in to the case. Typically in close proximity to the cord there is a fuse in a screw-in type receptacles, usually black in color. PLEASE UNPLUG THE UNIT TO REMOVE IT.
Sep 29, 2010 | Sun StorEdge L8 Autoloader Ultrium Tape...
Need password
The default username is admin
The default password is 0000
Aug 29, 2009 | Areca ARC-1110ML PCI-X SATA RAID - 4 Ports...
Raid 5 crashed
Hi Chris,
How many drives are part of the array and what type are they? Are the drives making any unusual sounds like clicking or screeching? If not, then you should be able to recover the data. If the drives are making clicking sounds, you will probably need a professional data recovery service that specializes in Raid 5 data recovery to help you.
If the controller shows that only 1 drive is bad, you should be able to rebuild it by replacing that drive. If the controller shows all the drives are bad, then it is most likely a problem with the Raid 5 controller itself. In this case, you could try putting the drives in a working version of the same enclosure/controller.
Check the obvious also, like loose connections to the drives. Whatever you do, dont force a rebuild as this will probably result in permanent data loss.
Wesley Gill
Gillware Inc.
Raid Recovery Info
Aug 28, 2007 | D-Link DNS 6040M (DNS-6040M) Hard Drive...
Problem with L100 TAPE LIBRARY
I'm having a similar issue.. anyone know how to fix these?
CH 2635
Library.c
Line 4231
Path 0000
Aug 12, 2007 | Sun StorEdge L100 Tape Drive
System not detecting the disk array.
Hi there, You apparently don't have downloaded all drivers and software needed. I'd go to: http://www.sun.com/products-n-solutions/ hardware/docs/Network_Storage_Solutions/Adapters/index.html. Install the software in the following sequence: 1. Download and install Sun StorEdge SAN Foundation software 4.2 packages and patches. See Sun StorEdge SAN Foundation Software 4.2 Installation Guide, 817-1244. 2. Download and install the appropriate JNI 2 Gb PCI Single and Dual Port HBAs packages and patches. See JNI 2 Gb PCI Single and Dual Port Fibre Channel Host Bus Adapters Release Notes, 817-2260. Good luck!
Sep 13, 2006 | JNI FCX2-6562-E Network Adapter
Sun StorEdge L25 (SG-XLIBL25D-BASE) DLT Tape Drive Logo
239 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
