Question about Janome Memory Craft 4000 Sewing Machine
Bobbin thread bunching
After about an hour of sewing on my Janome Memory Craft 4000, the thread begins bunching on the underside of the fabric and gets increasingly worse. There is also a terrible racket coming from the bobbin case area that gets progressively louder. What I have done so far: had the machine completely serviced by an authorized dealer in Sept. 2007. I had only minor stitching problems before service. Machine sewed fine under sporadic sewing conditions until this week when I began sewing with a deadline on quilted art projects. These are linen or silk over flannel so I'm not asking the machine to do heavy duty sewing. Monday I took the machine into a sewing machine person who adjusted the tension top and bottom. It worked beautifully about 3 hours. Then the problem began all over again. I turned the machine off for the night and it is stitching a little better this morning, but it is still noisy and I predict that it won't take much sewing before the thread begins bunching on the underside of the fabric. Help, I have a big deadline and need my machine. Short of throwing it into the river or buying a new machine, what can I do? Thanks, Sandy
  • sandymom Feb 24, 2008
    Thank you. Your reference to adjusting tension that you posted for someone else was very helpful. sandymom
  • Anonymous Mar 25, 2014
    top thread gets entangled in shuttle often and i need to dismantle the shuttle atleast 10 times before stitching a frock. its a new single singer sewing machine
  • Janome Master
  • 1,388 Answers
I agree with brodering about the damage to your bobbin case, it should be smooth all over, as the thread travels across the top surface to form a stitch, and the small step on the underside locates it as the hook spins underneath.
Needle strikes often compromise the surface, as will the hook colliding with the under surface... and although it is possible to gently polish off the damage with fine grain wet & dry (black) sand paper (emery paper) there are limits to the success depending on the degree of damage.
While on the subject, ensure the bobbin case and hook race beneath are clean and free of lint or thread.
For a guide as to setting tensions and the rest, look here
Posted on Feb 24, 2008
    Problem Solver:
  • 15 Answers
Remove your needle plate, and take out the black bobincase. Check the edges on the black bobbincase for scratches or damages. The upper tread should glide smootly around the upper edge of this bobbincase.
If you find any scratches, you may use a very fine sandpaper/grindingpaper (not shure what you call this in english) to remove the scratches.
Posted on Feb 23, 2008
When sewing after 5 mm the top color cotton is building under the material and stops.I opened it up clean the dust and still the same. can some one give me a hint please . thanks."?"
Remove the upper thread completely. Install a brand new needle. RAISE the presser foot and rethread from the beginning. Confirm with the owner's manual the threading pathway is correct. Set the upper tension to the midway point between the high & low number. Retest.
Correct tension is when the upper and bobbin threads meet in the middle of the fabric. If bobbin thread is showing on the top of the fabric, loosen the upper tension. If upper thread is showing under the fabric, tighten the upper tension.
Make sure the thread, needle, and fabric are compatible.
All About Needles
Mar 06, 2016 | Janome Memory Craft 4000 Sewing Machine
My bobbin thread is part of my embroidery on my memory craft 11000
you may have the fabric not tight enough in the hoop or try using the same colour thread in the bobbin
Nov 02, 2014 | Janome 11000 Memory Craft Special Edition...
I am trying to set my Memory Craft 4000 machine to do free hand quilting. I have lowered feed dogs and put on the darning foot. when I practice the top looks great but on the underside of the fabric the...
Sounds like you have no tension on the upper thread. Rethread the top thread, make sure you have the pressure foot raised, and have your tension around 5. Don't forget to lower the pressure foot before you began to sew.
May 11, 2011 | Janome Memory Craft 4000 Sewing Machine
I just bought a memory craft 6600 the thread from the bobbin keeps looping on the top fabric? When I change the tension number it just gets worse Help
Check your threading, especially your bobbin because usually looping on top means the bobbin is not set right, Read your manual,
Aug 24, 2010 | Janome Memory Craft 9000 Computerized...
The top thread on my Janome 300E is getting caught in the bobbin. It starts bunching up on the back of the fabric that I am trying to embroider and it gets stuck. When I pull it off all the top thread is...
If your thread is getting caught underneath it's usually the UPPER thread is threaded wrong or not correctly through the tension discs. This can also happen if you're using Sticky Back stabilizer. Make sure you have a new needle in case there's a burr on the old one which can also cause this problem.
Aug 22, 2010 | Janome Memory Craft 3000
tension is tooooo loose.
slowly tighten
also the pressure gauge at the top should be for accurate fabric thickness
May 30, 2009 | Janome Memory Craft 3000
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
385 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
