Question about Toshiba 50H82 50" Rear Projection Television
No sound after replacing hyper module on a toshiba 50h82
  • surillis Feb 05, 2010
    could you detail its general location and give a brief description?
    I have a Toshiba (50H82) 50" projection screen television. In which I recently replaced its hyper module. Before the module was replaced the set had sound on all inputs, but after the modules replacement there was no sound at all. I have insured all connectors are seated and in there correct places. I have a service manual for the tv but it seems to be lacking as to the tv's audio circuits. Any input as to what the problem could be would be appreciated. In an earlier post it was mentioned it might be the audio ic module. I thank you all for your help.
    Roy
  • 10,594 Answers
Make sure AV module is fixed correctly in Signal board.
Hyper module has nothing to do with tv sound circuit.
Sound switching is in AV board and sound out chip Q601 is on main signal board.
Do you get sound on monitor out pins at tv back?
Thanks.
Posted on Feb 05, 2010
  • Toshiba Master
  • 5,138 Answers
Replace the Audio output IC they have high failure rate.
Posted on Feb 04, 2010
  • ladywinn
    ladywinn Feb 05, 2010
    Circuit modification Part# 23009142 for ICqd01
Picture of hyper module board toshiba 57h84
Toshiba or any authorized service center can pull up the photo of that board (the 10 caps that fail are all indicated with red arrows) you are aware they are surface mounted caps?
Oct 28, 2012 | Toshiba 50H82 50" Rear Projection...
The picture on our Toshiba 50H82 rear projection tv is shaky, any diy solutions for this?The picture will sometimes clear up after about 30 minutes. Can this be fixed? The sound is fine, it's just the...
Thats almost always caused by the surface mount capacitors which get weak on the hyper board. Hyper boards are going to be hard to find. But the capacitors can be replaced which will usually solve the issue. However it will require precise soldering skills to do the repair.
Oct 06, 2011 | Toshiba 50H82 50" Rear Projection...
Hi i Have a Toshiba 50H82 all the colors is good but the picture is really blur and shake, does someone knows of to fix it, im not shure if its call the tuner of the tv....
If the video is shaking, zig zag looking, etc your hypermodule has failed. This is common on your model. Some peeople call it hyper board, hyper module, etc..all the same.
You can get a repair kit for this from www.TvRepairKits.com
Oct 19, 2010 | Toshiba 50H82 50" Rear Projection...
Will a REBUILT PTS PART number pd0637 toshiba hyper, number on part MVPU14 2L20DD work as a hyperboard in a 2002 50h82
Most of these hyperboard are inter changeable.But must Check the 2 STK convergence ICS munbers on the ICS parts have the same printed #---?
Apr 01, 2010 | Toshiba 50H82 50" Rear Projection...
Horizontal scrolling after it was moved to another room
The Hyper module has failed or the connection on the module isnt tight
Nov 26, 2009 | Toshiba 50H82 50" Rear Projection...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
When I turn on my 50H82 it takes 10 to 15 minutes
I just did a repair on one of these. Check your picture-on-picture. If the the secondary picture is clear, chances are very good the problem is on the "hyper board". We d not replace the hyper board - we repair it. The board is very expensive and rarely, if ever, available. There are several parts in the module that need replaced, but these are definitely not user replaceable. They are very small surface mount components and even I have lifted a copper or trace or two doing these. It is tedious work but our repair bill was well below $300. It is also something I do not do in the home and taking it to the repair facility is a money saver. I did go to the home on this one and remove the board to the shop, however they only lived a few miles away so the service call was low priced. Hope this helps...
Feb 23, 2009 | Toshiba 50H82 50" Rear Projection...
Picture problem on 50H82
the hyper module needs replacement or repair.
there are many dried surface mount caps on the board and they are dried out. best let a tech do the job
Jun 17, 2008 | Toshiba 50H82 50" Rear Projection...
Wavy lines when i turn on the tv
this is a typical hyper module replacement job let a tech do it.
not for the do-it-yourself type.
May 26, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba - 50H82 service manual
Don't buy a hyper module simply replace the smt lytics with some mini cam radials cut to fit. You will be looking to replace Cx261, Cx230, Cx270, Cz52, Cx178, Cx221, C514, Cx250, Cx670, Cx241 and Cx541 all of them 16v/10uf... The Hyper is easy to locate it's the large metal cased vertical board just behind the jack panel. Two screws and some patience getting it out and you should have it repaired in less than an hour.
I do have the service manual and would be glad to send it, email me privately for a link.
Bill
premtech@willapabay.org
Mar 20, 2008 | Televison & Video
Toshiba 50H82 50" Rear Projection Television Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
